Question about reaction mechanism in ReactingFoam
Old   June 20, 2014, 00:45
Default Question about reaction mechanism in ReactingFoam
Daniel
Dan1788 is on a distinguished road
Hello all,
I was studying the ReactingFoam reaction mechanism in OF 2.2. Instead of having the usual mechanism as given in the tutorial, I included a new one step mechanism given by Westbrook and Dryer (1981) as shown below:
species
5
CH4
O2
CO2
H2O
N2
reactions
un-named-reaction-0
type irreversibleArrheniusReaction;
reaction "CH4^-0.3 + 2O2^1.3 = CO2 + 2H2O";
A 1.3e+09;
beta 0;
Ta 24354.5;
Unfortunately however, when I use this mechanism I get an error that is:
--> FOAM FATAL ERROR:
Singular matrix
From function LUdecompose(scalarSquareMatrix& matrix, labelList& rowIndices)
in file matrices/scalarMatrices/scalarMatrices.C at line 60.
FOAM exiting
Can someone please let me know why I am getting this message? Is there something wrong with the format of the mechanism or am I missing something?
Would really appreciate help. Thanks!
Dan1788 is offline   Reply With Quote
Old   June 20, 2014, 07:43
Franco Marra
francescomarra is on a distinguished road
Dear Daniel,
from my experience, the Westbrook & Dryer mechanism (W&DM) you are trying to use is not so "easy" . I am not able to understand, from the few rows of your output, when the error occurs: when reading the mechanism of during the computation ?
The problem with the W&DM arises from the negative exponent of methane. To check if this is the problem, you could try to lower the preexponential factor and/or use a unitary exponent for the methane. Of course results are not meaningful, but you can check if you are correctly programming your reaction and if the reactingFOAM code is able to deal with negative exponents of species.
The literature offers several other one-step global and irreversible mechanisms, usually valid for a restricted range of equivalence ratios, but with unitary exponents for the concentrations.
Best regards,
Franco
francescomarra is offline   Reply With Quote
Old   June 20, 2014, 11:42
Daniel
Hi Franco,
Thanks a lot for your message.
The error message I posted was coming at the start of the simulation, while reading the mechanism. I changed the methane exponent from -0.3 to 0.3 and the simulation worked fine! Any idea why this happens?
Thanks again!
Old   June 23, 2014, 06:55
Franco Marra
Dear Daniel,
unfortunately I am not very familiar with the OpenFOAM implementation of the chemical terms. However the problem usually arises because of the behaviour of any power function with negative coefficient. When the argument keeps close to zero, the function tends to infinity. Then, or the production term explodes (making unstable the whole computation) or at zero you have a NaN value.
Actually, it is known that the W&DM is correct, but it takes into account only a planar flame, a idealized situation where it easier to keep the correct relative importance of both reactants. Here comes into play the actual implementation of the mechanism.
Best regards,
Franco
Old   January 14, 2016, 06:03
Howar
Howard is on a distinguished road
Hi, Daniel. I met the same question. Have you solved the problem?
Howard is offline   Reply With Quote
Old   September 8, 2016, 11:31
Fabrizio
fabri is on a distinguished road
Hi Daniel and Howard,
I met the same problem too.
Have you solved it?
Thank you very much
Fabri
fabri is offline   Reply With Quote
Old   December 13, 2016, 06:09
Emre
ordinary is on a distinguished road
I have also same problem.
ordinary is offline   Reply With Quote
Jet-A/air reaction mechanism in FLUENT Jenny_W FLUENT 1 November 29, 2013 02:12
CHEMKIN new reaction type (reactingFoam) vbchris OpenFOAM Programming & Development 0 July 27, 2013 16:53
question about udf for "particle surface reaction rate" lili Fluent UDF and Scheme Programming 0 January 9, 2013 04:37
reactingFoam Enthalpy of Reaction Problem Cyberholmes OpenFOAM 1 August 23, 2011 06:23
turbulent mixing controlled reaction vs. chemical kinetics controlled reaction Hyeryung NA Main CFD Forum 10 November 11, 1999 04:00
