Viewfactors - specified fixed radiation wall heat flux |
June 12, 2014, 05:00 |
Paweł Kuczyński
Rep Power: 15 |
Dear forumers,
is it possible to specify fixed total radiation wall heat flux using viewfactors radiation model in OpenFOAM? I've looked into the boundary conditions for radiation in the path: Code:
/opt/openfoam211/src/thermophysicalModels/radiationModels/derivedFvPatchFields/ Code:
boundaryField { minX { type greyDiffusiveRadiationViewFactor; value uniform 0; emissivityMode lookup; emissivity uniform 1; Qro uniform 0; } } Any help is appreciated.
Best regards P. Kuczynski. Last edited by kuczmas; June 12, 2014 at 07:21. |
June 12, 2014, 07:27 |
Paweł Kuczyński
Rep Power: 15 |
Ok, I did my homework and cheked the meaning of Qro inside the class of greyDiffusiveViewFactorFixedValueFvPatchScalarFiel d.H.
So Qro is "external radiative heat flux". Therefore, I think it is not possible to specify total (net) radiative heat flux at wall. Correct me if I'm wrong...
Best regards P. Kuczynski. |
boundary condition, heat flux, viewfactor |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Looking for a code of exact wall heat flux on cylinder enclosure wall | ljwbuaa | Main CFD Forum | 5 | January 16, 2011 08:33 |
calculation of wall heat flux in CHT | richard | CFX | 1 | July 23, 2009 09:00 |
CFX - wall heat flux | divarano | CFX | 2 | December 4, 2006 16:14 |
Cavity air flow with radiation – result variable | Yingchun | CFX | 1 | November 25, 2005 11:13 |
