June 7, 2014, 05:40 |
LES pipeflow dynOneEddy strange results
Florian Ries
Rep Power: 12 |
Hi all,
I've done some LES simulations of pipeflow with dynOneEddy-Model and compare my results with oneEddy-Model and WALE model. I get some strange results for ksgs -> nuSgs. first some informations: 1) problem description - pipe diameter 0.04m - length of the pipe 4*D (cyclic Boundary conditions) - fluid water nu=1.081e-06 - incompressible flow Re=4900, Retau=340 - Grid: structured O-Grid r+ wall = 2,5 r+ mean = 7.5 z+ = 35 eta+ = 10 I have also used finer grid and I have the same problem (problem see below) 2) Boundary conditions: ---k , p , nuSgs--- boundaryField { inlet { type cyclic; } outlet { type cyclic; } pipewall { type zeroGradient; } } ---U --- boundaryField { inlet { type cyclic; } outlet { type cyclic; } pipewall { type fixedValue; value uniform (0 0 0); } } 3) Schemes/Solution/Options - I used pressureGradientExplicitSource to get the cyclic flow. - all schemes Gauss linear or Gauss linear corrected - ddtSchemes: backward - pimple with residual control U,p<10^-5, k<10^-7 - initalize the U-field fully turbulent by mapping data from other simulation - fieldAverage 200D The velocity profiles in u+ y+ looks ok for all models (dynOneEddy is ok but the others are better). But in dynOneEddy-model I get strange behavour for nuSgsmean and kSgsmean. --------- Here my results for nuSgsmean over 200D---------- 1. WALE: SmagNuSgsmean.jpg looks good. At the wall, nuSgs decrease because of WALE model. NuSgs is smooth ober the domain 2. OneEddy OneNuSgsmean.jpg results looks reasonable, because I do not use van Driest damping at the wall and it is not a dynamic procedure implemented. But nuSgs is smooth. 3. dynOneEddy dynOneNuSgsmean.jpg looks not good!! Why these two stripes??? ------ Here my results for kSgsmean------------- 1. OneEddy OnekSgsmean.jpg looks reasonable, because no dynamic procedure implemented. 2. dynOneEddy dynOnekSgsmean.jpg puuh, What's going on at the wall?? What about these two stripes again?? In dynOneEddy-model the results for nuSgsmean and kSgsmean looks strange. First I thought it is the grid. But even with finer grid I get the same results. For Smagorinsky, dynamicSmagorinsky, WALE, OneEddy-model I get with this mesh, bc etc. good results. Whats wrong with dynOneEddy-model??? Is there a fault in the implementation of the dynamic procedure in dynOneEddy-model?? Somebody an idea??? kind regards Florian |
June 9, 2014, 12:59 |
Florian Ries
Rep Power: 12 |
is there somebody with experience with dynOneEddy-Model???? kind regards Florian |
March 15, 2017, 01:47 |
zhaoshiyu
Rep Power: 9 |
doubt about DNS and LES of combustion | chinthakindi | Main CFD Forum | 5 | August 17, 2013 11:56 |
Newton Raphson - strange results | Bren | Main CFD Forum | 5 | February 11, 2009 10:47 |
Strange results of car drag/downforce | Tudor Miron | CFX | 4 | March 14, 2004 05:49 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
RANS results for LES | Li Yang | Main CFD Forum | 5 | June 17, 2002 05:34 |
