Reverse Flow
Old   June 5, 2014, 16:03
Xiangyu Gao
gxy200992243 is on a distinguished road
Hi, everyone!
Now I am dealing with flow of a car rear mirror. There are two major mistakes in my simulation results, and I cannot figure out the reason.
1 Reverse flow is observed at outlet of the domain.
2 I set the upwall and side wall to be moving with a velocity of 39m/s, but the simulation results show zero velocity at the upwall and side wall.
I am using the Smagorinsky model. ck=0.05,ce=1.05. The streamwise velocity contour is also attached.
Can anyone help me deal with these two problems? Billions of thanks!
Information about my boundary conditions is listed below:
boundary
    movingWall
        type            wall;
        nFaces          17380;
        startFace       3061330;
    wall
        type            wall;
        nFaces          19320;
        startFace       3078710;
    outlet
        type            patch;
        nFaces          7700;
        startFace       3098030;
    inlet
        type            patch;
        nFaces          4540;
        startFace       3105730;
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 -39);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 -39);
    outlet
        type            zeroGradient;
    wall
        type            fixedValue;
        value           uniform (0 0 0);
    movingWall
        type            fixedValue;
0/p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    wall
        type            zeroGradient;
    movingWall
        type            zeroGradient;
0/nuSgs
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    wall
        type            zeroGradient;
    movingWall
        type            zeroGradient;
0/nuTilda
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
    wall
        type            zeroGradient;
    movingWall
        type            zeroGradient;
Last edited by wyldckat; June 8, 2014 at 09:57. Reason: Added [CODE][/CODE] and merged posts made few minutes apart
gxy200992243 is offline   Reply With Quote
Solution is converging but have reverse flow on pressure outlet Dinesh_Dhande Main CFD Forum 2 March 11, 2018 02:02
Eulerian Granular flow:receive reverse flow and solution isn't converge bahman FLUENT 1 January 2, 2014 12:53
Reverse flow at boundary andyross33 CFX 2 August 27, 2013 14:24
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 16:05
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 10:14
