June 5, 2014, 04:17 |
floatingObject in 2D
Rep Power: 16 |
I am trying to model a floating object in 2D and 3D. In 3D everything is fine but in 2D my object sinks almost immediately. I noticed that in 2D my volume is obviously much smaller and if I scale down my mass to be consistent, then everything is fine but then the system would be different than the 3D system (my case is connected to spring-damper), and I need to also modify the moment of inertia. I did a test and increased the length of my domain in the 3rd dimension but keeping only one cell in that direction. Now the forces are correct and the system is floating but the mesh aspect ration is not good. guys, any advice on how to set the parameters correctly is highly appreciated. |
June 10, 2016, 18:11 |
Gautami Erukulla
Rep Power: 17 |
Hello Ashkan,
I am trying to model a 2D floating object. I made changes to the floating object tutorial, but the object sinks and the simulation blows. Were you able to get a working case for the 2D floating object? If yes your guidance will be appreciated. Thanks. Most&More, Gautami Erukulla. |
floating objects, waves2foam |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 07:35 |
OpenFOAM Tutorial 3D floatingObject strange jump ? | lavrov | OpenFOAM Running, Solving & CFD | 4 | November 20, 2013 06:38 |
no floatingObject patch generated in tutorial "floatingObject" | yejungong | OpenFOAM Running, Solving & CFD | 1 | August 8, 2013 22:43 |
[blockMesh] problem with blockMesh in floatingObject tutorial | atulAtcae | OpenFOAM Meshing & Mesh Conversion | 4 | October 6, 2012 04:35 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 16:24 |
