k-omega calculation of wigley hull case
Old   June 2, 2014, 04:54
Default k-omega calculation of wigley hull case
kansetsu7 is on a distinguished road
hello, I run the wigley hull cases download at
http://sourceforge.net/projects/open.../EricPaterson/
the case goes well, but I have question about the k and omega value
in "steadyResistance" case I use http://www.cfd-online.com/Tools/turbulence.php and following Properties to calculate k & omega
Freestream velocity=1
Turbulence intensity/level=1
Kinematic viscosity=1e-6
Eddy viscosity ratio=10
the result is k=0.00015, omega =15
but in the steadyResistance case is k=0.00015(same), omega =2
also, in the "transientResistance" case
use: Freestream velocity=2
the result is k=0.0006, omega =60
but in the transientResistance case is k=0.1, omega =400
Why the k&omega values I calculated is different from the tutorials?
kansetsu7 is offline   Reply With Quote
transportProperties phase1, Wigley hull kolloff OpenFOAM Running, Solving & CFD 0 March 1, 2011 15:00
wigley hull davedave121 ANSYS 0 March 8, 2010 16:25
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Warning 097- AB Siemens 6 November 15, 2004 05:41
Wigley hull test case giovanni ieria Main CFD Forum 0 November 22, 1999 12:30
