Floating point exception using icoFsiFoam even with zero flow
Old   May 31, 2014, 16:32
Default Floating point exception using icoFsiFoam even with zero flow
Nikolac is on a distinguished road
Hello everyone,
my work is on the biophysics of hearing and in particular, I am interested in the interactions between fluids and membranes inside the cochlea. Reading this forum, I don't seem to be the only one
From my earlier education, I have no background in CFD and basic capacities in C++. During the last few months I have fought my way through some basic features of OpenFOAM (took me a while until I got my mesh to move the way I wanted), but now I'm at my wit's end, and the forum threads so far don't appear to be helpful either...
As a test case, I want run a FSI simulation where the flow comes from a cylinder (2D) moving up and down periodically. This should lead to deformations of the upper wall of the geometry (eventually I would like to replace it by a membrane between two fluid regions). Apart from the geometry, the dictionaries are left as in the flappingConsoleSmall tutorial case.
However ... that leads to a floating point exception error after very few time steps. This happens even if there is zero prescribed motion in the first place. Instead of everything remaining at rest at all times (how much easier can a simulation get?), the computation crashes.
I have attached the log and a screen shot of my geometry. What am I missing? Can this even work or am I being too naive? I would sincerely appreciate any suggestion!
Thanks, N
Nikolac is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
pimpleDyMFoam constantly giving floating point exception and solution divergence fedvasu OpenFOAM Running, Solving & CFD 0 November 28, 2013 01:53
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 17:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 04:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
