twoliquidmixing foam
Old   May 23, 2014, 10:46
Default twoliquidmixing foam
gdhi is on a distinguished road
i am trying seawater dispersion ( inclined jet) in fresh water using TwoLiquidMixingFoam. when diverging the time step gets reduce to very low values min(alpha) value is -8.0 what are the possible outlet boundary conditions for this case.
thanks
gdhi is offline   Reply With Quote
Old   June 25, 2014, 17:12
Joachim Herb
jherb is on a distinguished road
What are your current settings for the boundary conditions and for fvSchemes/fvSolution? This might help to debug your case.
jherb is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
