Porous Media
Like Tree21Likes
Old   November 3, 2016, 01:46
Jue Wang
Joe Wang is on a distinguished road
Thank y'all. This thread and the replies help me a lot.
Joe Wang is offline   Reply With Quote
Old   February 15, 2017, 08:37
Default unsteady calculations
  #22
Kapa Lilla
klilla is on a distinguished road
Dear All,
I have a question regarding using the porosity approach for unsteady flows. In the past (v2.x, I do not exactly remember), there was a function pZones.ddt to take into account the delay due to the superficial velocity, but when I look at the class definition of the porous zones in /src/finiteVolume/cfdTools/porosityModel/porosityModel, I cannot find such functionality as there was before. Why is it so?
Thanks for your comment on this,
Lilla
klilla is offline   Reply With Quote
Old   September 16, 2017, 01:43
Default Multiple porous zones
  #23
karundev
krndv is on a distinguished road
Hello All,
I am solving a case with a geometry having multiple porous zones, means each zones have different values of D anf F.
For simplicity consider it as a rectangular dust with 3 poorus zones.
If I want to use snappyHexMesh, Can I just draw a rectangle and mesh with out seperating zones and later define cellzones using toposet?
krndv is offline   Reply With Quote
Old   September 17, 2017, 04:18
Kapa Lilla
Yes, you can. Though you should double check if your zones defined well. Moreover, you might end up having zones slightly smaller or larger, depending where you have a face-layer ending.
But otherwise, it is a fast and easy way to do it.
Old   September 17, 2017, 06:40
Default topoSet
  #25
karundev
Can you please give short idea about setting up topoSetDict?
Old   June 22, 2021, 13:38
Default modeling a mving porous media in openfoam
  #26
Snigdha
sniggy is on a distinguished road
Hi Everyone,
I am new to openfoam. I want to model a moving packed bed with air flow. I also want to do a heat transfer in the porous solid and fluid. Moving packed bed, I suppose, can be solved by moveDynamicMesh. The air flow dynamics can be solved i a fixed poros media by porousSimpleFoam. But I dont have any idea ho to solve them together?
sniggy is offline   Reply With Quote
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
