Laval nozzle simulation fails
Old   May 19, 2014, 13:39
Question Laval nozzle simulation fails
M. Hüther
der-hüther is on a distinguished road
Hello everybody,
although there exist already a lot of threads concerning this subject, I decided to start a new one.
Since some weeks I try hard to simulate a Laval Micro-Nozzle (CD-Nozzle) with a throat to outlet ratio of 1:3 (outlet diameter: 7 mm) using the following boundary conditions:
The initial pressure at the inlet should be 50 bar, the initial pressure at the outlet should be below 1 mbar. The gas used is Argon, the initial temperature at the outlet is 300 K.
The program crashes in most cases after a few time-steps or does not even start computing.
The higher I choose the pressure gradient between inlet and outlet, the earlier the program crashes.
I draw my geometry with Autodesk Inventor and imported it to Salome.
The Salome Mesh is generated with the NETGEN 1D-2D-3D algorithm and is as fine as possible.
After saving it as .unv and converting it to a OpenFOAM file I started simulations with various different boundary conditions.
The mesh check gives "Mesk OK". The solver I used is rhoCentralFoam, but I also tried sonicFoam.
For both solvers the Courant Numbers were far below 0.1.
The most reasonable BCs are:
for 0/p:
internalField   uniform 0;
boundaryField
    inlet
    type            totalPressure;
    p0                uniform 5e6;
    gamma            1.66;
    wall
    type               slip;
    outlet
    type        waveTransmissive;
    gamma        1.66;
    field        p;
    phi             phi;
    rho             rho;
    fieldInf    0;
    lInf        0.1;
for 0/T:
internalField   uniform 300;
boundaryField
    inlet
    type         fixedValue;
    value        uniform 300;
    wall
    type          slip;
    outlet
    type            zeroGradient;
for 0/U:
internalField   uniform (0 0 0);
boundaryField
    inlet
    type            pressureInletOutletVelocity;
    inletPressure    uniform 5e6;
    value        uniform (0 0 0);
    wall
    type                slip;
    outlet
    type        zeroGradient;
for constant/thermophysicalProperties:
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles          1;
        molWeight       4.0;
    thermodynamics
        Cp              5.193e3;
        Hf              5.23e3;
    transport
        mu              1.86e-5;
        Pr              0.66;
for constant/turbulenceProperties:
simulationType  laminar;
for system/fvSchemes:
fluxScheme      Kurganov;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    reconstruct(rho) vanLeer;
    reconstruct(U)  vanLeerV;
    reconstruct(T)  vanLeer;
snGradSchemes
    default         corrected;
for system/fvSolution:
solvers
    "(rho|rhoU|rhoE)"
    solver          diagonal;
    U
    solver          smoothSolver;
    smoother        GaussSeidel;
    nSweeps         2;
    tolerance       1e-09;
    relTol          0.01;
    e
    $U;
    relTol          0.1;
for system/controlDict:
application     rhoCentralFoam;
startFrom           startTime;
startTime           0;
stopAt              endTime;
endTime             1;
deltaT              0.0000001;
writeControl        adjustableRunTime;
writeInterval       0.000001;
purgeWrite          0;
writeFormat         ascii;
writePrecision      6;
writeCompression     off;
timeFormat          general;
timePrecision       6;
graphFormat         raw;
runTimeModifiable     true;
adjustTimeStep      yes;
maxCo               0.2;
maxDeltaT           1;
I always get the error
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib64/libc.so.6"
#3  Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#4  Foam::psiThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5  Foam::autoPtr<Foam::psiThermo> Foam::basicThermo::New<Foam::psiThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#6  Foam::psiThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
 at ??:?
#8  __libc_start_main in "/lib64/libc.so.6"
 at ??:?
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
Has anybody an idea what I'm doing wrong? It would be great if someone could help me!!!
Thanks a lot
der-hüther
Last edited by der-hüther; May 21, 2014 at 13:23. Reason: new thermophysical parameters
der-hüther is offline   Reply With Quote
Old   September 3, 2014, 06:57
Marco
geronimo_750 is on a distinguished road
Hi Der-Huther,
I am trying to solve a quite similar problem and I am getting the same error you got.
Did you find a way to fix it?
Regards,
Marco
geronimo_750 is offline   Reply With Quote
boundary conditions, converging-diverging, laval nozzle, rhocentralfoam
2D Nozzle vapor simulation xof5006 FLUENT 0 December 18, 2012 22:51
How to visualise the shock wave in a laval nozzle? xck1986 OpenFOAM 1 January 20, 2011 05:31
Laval Nozzle in tunnel configuration? Robert2011 FLUENT 0 January 17, 2011 17:47
Nozzle - Simulation converges, but data incorrect fade CFX 0 July 20, 2009 05:13
Need assistance in BC's for simulation of Vacuum cleaning nozzle bruce OpenFOAM Running, Solving & CFD 0 May 22, 2009 14:56
