Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0
Old   May 15, 2014, 05:17
Default Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0
Jiri
Jiricbeng is on a distinguished road
I have of 2.3.0 and I installed 1.6ext version. However although I use command of16ext to switch openfoam version I cant make run cases which run under openfoam 2.3.0, such as simpleFoam.. Where is the mistake?
Jiricbeng is offline   Reply With Quote
Old   May 15, 2014, 05:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
what exactly did you mean by
There can be lots of things: slightly different dictionary formats, wrong environment variables, etc.
alexeym is offline   Reply With Quote
Old   May 15, 2014, 05:32
Jiri
I mean - I have a simple case I created - a box with velocity inlet and pressure outlet (k - eps model) which worked fine in of 2.3.0. And when I write command to switch from 2.3.0. to 1.6ext and write "simpleFoam" to start calculation, it writes
| \\ / F ield | OpenFOAM Extend Project: Open source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
Build : 1.6-ext-064a6e9f332e
Exec : simpleFoam
Date : May 15 2014
Time : 11:33:24
Host : 96GB
PID : 6070
Case : /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
--> FOAM FATAL IO ERROR:
Cannot open include file "/home/openfoam/OpenFOAM/OpenFOAM-1.6-ext/etc/caseDicts/setConstraintTypes" while reading dictionary "/home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/0/p::boundaryField"
file: /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/0/p at line 24.
From function functionEntries::includeEntry::includeEntry(dictio nary& parentDict,Istream& is)
in file db/dictionary/functionEntries/includeEntry/includeEntry.C at line 105.
FOAM exiting
Have got any idea, what is wrong?
Old   May 15, 2014, 05:44
Alexey Matveichev
Can you show your 0/p file? I guess the problem is in the line
#include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes"
There's no such file in 1.6-ext. As I don't know detail of your case, for the start I'd suggest you to comment out the line.
Old   May 15, 2014, 05:57
Jiri
I uploaded the case here http://leteckaposta.cz/843824944. You can have a look at the files. I will be really glad for help.
Old   May 15, 2014, 06:22
Alexey Matveichev
Well, you need to remove (or comment out) line:
in 0/U and 0/p files. As in fact you don't need this line even if you're running the case with 2.3.0.
Old   May 15, 2014, 07:32
Jiri
Thank you,
however I still have the message:
keyword div((nuEff*dev(grad(U).T()))) is undefined in dictionary "/home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/system/fvSchemes::divSchemes"
file: /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/system/fvSchemes::divSchemes
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 396.
FOAM exiting
Although I commented out the div((nuEff*dev(grad(U).T()))) in /fvSchemes (I also tried to comment out other lines in fvSchemes) it still writes the message above (I tried to close and open terminal as well)
Old   May 15, 2014, 09:06
Alexey Matveichev
Well, you can't solve everything by just commenting it out
If you go to 1.6 tutorials, you'll find, this line
div((nuEff*dev(T(grad(U))))) Gauss linear;
should be
div((nuEff*dev(grad(U).T()))) Gauss linear;
The reason for it is the implementation of turbulence->divDevReff(U) method. If you look at UEqn.H:
    tmp<fvVectorMatrix> UEqn
        fvm::div(phi, U)
      + turbulence->divDevReff(U)
and then look at kEpsilon.C, in 2.3 divDevReff is:
tmp<fvVectorMatrix> kEpsilon::divDevReff(volVectorField& U) const
    return
      - fvm::laplacian(nuEff(), U)
      - fvc::div(nuEff()*dev(T(fvc::grad(U))))
while in 1.6 it is
    return
      - fvc::div(nuEff()*dev(fvc::grad(U)().T()))
That's why you need different lines in your fvSchemes for different versions of OpenFOAM.
Old   May 15, 2014, 09:52
Jiri
that is true, commenting out is a dull kind of solutin.
Thank you very much indeed mate, I finally used the whole files fvSchemes and controlDict from the 1.6ext tutorial, cause there were other fvSchemes errors.
Anyway, I would like to ask crucial question that I yearn to sort out, that is how could I run MRFSimpleFoam tutorial? There is folder "Make" and files createFields.H and MRFSimpleFoam.C, I do not know how to make it run. Could you give me a clue ?
Old   May 15, 2014, 10:07
Alexey Matveichev
If you're talking about tutorials/incompressible/MRFSimpleFoam/mixerVessel2D from 1.6 then there is Allrun script. In the folder tutorials/incompressible/MRFSimpleFoam/MRFSimpleFoam solver itself is located, it's not a case folder.
Old   May 15, 2014, 10:30
Jiri
Yes, I thought it is two separate folders ( mixerVessel2D and MRFSimpleFoam) I am just working with it (due to Allrun in mixerVessel2D).
Thanks a lot
Old   May 16, 2014, 03:56
Jiri
I am just going through the mixeVessel2D files. I obviously do not understand, what is actually the logic of MRFSimpleFoam - in this case I cannot see any mixing plane and there is no segment rotating, it is full circle.
I assumed in polymesh/boundary there will be a definition of cyclicGGI or GGI.. but there are just walls for rotor and stator.
Where can I find a case with rotating segmend connected via mixing plane to another segment or to a draft tube?
Old   May 16, 2014, 08:52
Jiri
I uploaded my rotor stator case I wish to simulate by using 1.6ext.
http://leteckaposta.cz/897752382
I d be very happy if you had little time to have a look at the case.
Old   May 18, 2014, 15:50
Retired Super Moderator
Bruno Santos
Greetings to all!
@Jiri:
I was planning on answering here on this thread, but after looking into this topic, I found out that 1.6-ext has the mixing plane feature in another branch and not in the standard one. And that it's preferable to install foam-extend 3.0, as it already has this feature integrated.
For more information, please read my revised post #7 on this thread: http://www.cfd-online.com/Forums/ope...tml#post492711
For future reference, looking for tutorials that have this mixing-plane feature, at least for now, can be done with this command:
find $FOAM_TUTORIALS -iname "*mixingPlane*"
Of course that this requires that you've installed a version of source code that has this feature
Best regards,
Bruno
Old   May 19, 2014, 08:11
Jiri
Thank you much for your information, I am just struggling with installation of extend -3.0. I am stuck on the step 11 which should last max 30 minutes, I waited nearly two hours and nothing.
Old   May 21, 2014, 04:52
Jiri
I successfully installed extended version 3.0.
I have meshes of stator.msh and rotor.msh which were created in commercial software. In OF 2.3.0 I used fluent3DMeshToFoam to convert meshes .msh to OF format. Then I used mergeMeshes and meshes were merged together.
However, I want to use mixing plane between rotor and stator, using OF3.0. I cant find where to set revolution of the rotor as I cant find it neither in tutorial mixingPlaneAxial nor in mixingPlaneDomADomB.
Moreover when typing simpleFoam a receive the error message:
Create time
Reading field p
Reading field U
Initializing the mixingPlane interpolator between master/shadow patches: outflow/wall-4
--> FOAM FATAL ERROR:
Face zone name outflowZone for mixingPlane patch outflow not found. Please check mixingPlane interface definition.
From function label mixingPlanePolyPatch::zoneIndex() const
in file meshes/polyMesh/polyPatches/constraint/mixingPlane/mixingPlanePolyPatch.C at line 724.
Cause in polymesh/sets I have only folders:
highAspectRatioCells
nonOrthoFaces
region0
region1
wrongOrientedFaces
How shall I get there files with zones, as in tutorial mixingPlaneAxial
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Test directory missing in OpenFOAM 1.6 ext andrewryan OpenFOAM 2 March 20, 2011 16:41
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Help I canbt run FoamX report Unable to contact name server error cornerstone OpenFOAM Installation 0 May 3, 2006 02:14
