increasing volume fraction in closed domain with compressibleInterFoam
Old   May 14, 2014, 13:58
Smile increasing volume fraction in closed domain with compressibleInterFoam
vigges is on a distinguished road
Hi Foamers!
I managed to extend the compressibleInterFoam solver by a time varying acceleration which, in my case, simulates a periodic motion and is provided by a file containing the time-acceleration tuples.
As you can see in the excerpt of my accFoam.C, I only introduced the acceleration in z-axis direction and defined a vector called acc which also contains the gravitation:
    while (runTime.run())
        #include "readTimeControls.H"
        #include "CourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        // --- time varying acceleration
        interpolationTable<scalar> lookup("acceleration.dat");
        scalar  acc_X = 0.0;
        scalar  acc_Y = 0.0;
        scalar  acc_Z = lookup(runTime.value());//timeSeriesAcceleration;
        Info<< "Acceleration in z-direction = " << acc_Z << nl << endl;
        const dimensionedScalar gunits("gunits", dimensionSet(0,1,-2,0,0,0,0), 1.0);
        dimensionedVector acc=g + vector(acc_X,acc_Y,acc_Z)*gunits;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
In order to take the acceleration into account I added the acceleration multiplied by my mixture density to the UEqn.H file:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(U)
      - rho*acc
Also, I extended the energy equation in the TEqn.H file as follows:
   fvScalarMatrix TEqn
        fvm::ddt(rho, T)
      + fvm::div(rhoPhi, T)
      - fvm::laplacian(twoPhaseProperties.alphaEff(turbulence->mut()), T)
            fvc::div(fvc::absolute(phi, U), p)
          + fvc::ddt(rho, K) + fvc::div(rhoPhi, K)
          - rho * (acc & U)
My test case, a closed test tube filled with 50% liquid sodium and 50% air "shaken" along the longitudinal axis according to a prescribed oscillating motion, yields good results for the liquid phase kinetic energy compared to a CFX case. However, during the simulation, the total liquid phase volume fraction defined by the initial filling level (0.5) is constantly increasing and reached a value of 0.58 so far. I have a suspicion that it has something to do with the compressibility of my fluids.
Speaking of which, I have doubts about the assigned value of R in my thermophysical properties for sodium. I had no idea how to calculate it, so I looked at the thermophysicalProperties.mercury from the compressibleMultiphaseInterFoam damBreak4Phase tutorial case and took a similar value, somy thermophysicalProperties.sodium looks like that:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles          1;
        molWeight       22.99;
    equationOfState
        R               5000;
        rho0            852;
    thermodynamics
        Cp              1277;
        Hf              0;
    transport
        mu              0.000264;
        Pr              0.00496;
I scanned the forum but only found threads related to decreasing alpha values. Maybe someone of you has already run into that problem before and found a solution for it.
Thanks a lot,
Victor
vigges is offline   Reply With Quote
acceleration, compressibleinterfoam, multiphase, volume fraction
volume fraction in mixture model and VOF???? multiphase-flow FLUENT 4 August 7, 2014 11:35
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Mass fraction and volume fraction eric weddle CFX 0 September 26, 2011 06:02
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
