coupled solver in OpenFOAM
Old   May 14, 2014, 05:40
Smile coupled solver in OpenFOAM
何刚
hg2lf is on a distinguished road
Is there any solver in OpenFOAM which solves all the equation ( continuity, momentum, energy, turbulence equation) at the same time? If so, we can calculate the compressible turbulent combustion flows. And how can we modify a slover or case in order to do this?
hg2lf is offline   Reply With Quote
Old   May 14, 2014, 07:16
Werner
Polli is on a distinguished road
You can take the coalChemistryFoam, it calculates continuity, momentum, energy, turbulence, and combustion. There is also a tutoial case "CoalChemistryFoam" in the lagrance case, which is maby the case you need. Skip the lagrange clouds, modify the mesh and i think you have what you need!
Polli is offline   Reply With Quote
Old   May 14, 2014, 07:38
何刚
Hello, Polli,
Where can I find coalChemistryFoam ? Is it in the OF-2.3.0?
Old   May 14, 2014, 08:06
Werner
i know its availible in OF2.2.0 so i think it is also in OF2.3 take a look in the tutorial at lagrange.
Old   May 14, 2014, 08:49
何刚
Thanks, Polli.
compressible, coupled solver
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 12:00
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
The seperated solver and coupled one summer FLUENT 0 July 5, 2006 16:06
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 09:30
