How to set the initial values of a simulation of flow around cylinder?
Old   May 11, 2014, 22:50
Question How to set the initial values of a simulation of flow around cylinder?
Wen Yuan
WenY is on a distinguished road
Hi
I wanna simulate flow around cylinder, But I am confused by the settings of the initial values in constant/0 file.Could anyone can help me?Here is my model.
WenY is offline   Reply With Quote
Old   May 11, 2014, 23:01
Wen Yuan
Here is my boundary settings code
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
 6
    cylinder
        type            wall;
        inGroups        1(wall);
        nFaces          260;
        startFace       38500;
    down
        type            wall;
        inGroups        1(wall);
        nFaces          90;
        startFace       38760;
    up
        type            wall;
        inGroups        1(wall);
        nFaces          90;
        startFace       38850;
    outlet
        type            patch;
        nFaces          40;
        startFace       38940;
    inlet
        type            patch;
        nFaces          40;
        startFace       38980;
    frontAndBackPlanes
        type            empty;
        inGroups        1(empty);
        nFaces          38760;
        startFace       39020;
Old   May 12, 2014, 09:22
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You might want to try the cylinder tutorial of potentialFoam.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   May 12, 2014, 22:09
Wen Yuan
Originally Posted by fumiya View Post
Hope this helps,
Fumiya
Thanks for your help! I've already solve the problem. I've made a mistake on the boundary condition located in constant/0 file.
Best regards,
WenY
initial values
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 06:58
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 14:38
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 06:36
