parallel running
Old   May 7, 2014, 06:53
Default parallel running
M. C.
student666 is on a distinguished road
Hi all,
just a silly question.
I'm running an icoFoam simulation using parallel computing with 4 cores
mpirun -np 4 icoFoam -parallel
my silly question concerning what i see on task manager. (enclosed a picture)
I see that 4 task are running (icoFoam -parallel), but CPU usage is about 25% each.
So my doubt rise frome thinking: 25%*4=100%.
The calculation (1700000 cells fully hexahedral) is going very slowly, I expected a quicker running.
The question is:
Is it possible to run a simulation by decomposing the case (I use scotch) into 4 cores, but the system uses only one?
Or other way, If I have 4 cores but I decompose into 6 core, parallel computing starts anyway?
Thanks for any help.
Michele
student666 is offline   Reply With Quote
Old   May 7, 2014, 07:49
Giulio
LaSerpe is on a distinguished road
I guess you're running on your personal machine, what are its spec?
LaSerpe is offline   Reply With Quote
Old   May 7, 2014, 08:14
M. C.
Hi Giulio,
yes it's my personal machine; I think you're asking for the following (I edit the post):
michele@KebaXubuntu:~$ lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    2
Core(s) per socket:    2
Socket(s):             1
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 37
Stepping:              2
CPU MHz:               2400.000
BogoMIPS:              4787.88
Virtualization:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              3072K
NUMA node0 CPU(s):     0-3
and
michele@KebaXubuntu:~$ cat /proc/cpuinfo
processor    : 0
vendor_id    : GenuineIntel
cpu family    : 6
model        : 37
model name    : Intel(R) Core(TM) i5 CPU       M 520  @ 2.40GHz
stepping    : 2
microcode    : 0x9
cpu MHz        : 2400.000
cache size    : 3072 KB
physical id    : 0
siblings    : 4
core id        : 0
cpu cores    : 2
apicid        : 0
initial apicid    : 0
fpu        : yes
fpu_exception    : yes
cpuid level    : 11
wp        : yes
flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat dtherm tpr_shadow vnmi flexpriority ept vpid
bogomips    : 4787.79
clflush size    : 64
cache_alignment    : 64
address sizes    : 36 bits physical, 48 bits virtual
power management:
processor    : 1
cpu family    : 6
model        : 37
stepping    : 2
microcode    : 0x9
cpu MHz        : 2400.000
physical id    : 0
siblings    : 4
core id        : 2
cpu cores    : 2
apicid        : 4
initial apicid    : 4
fpu        : yes
fpu_exception    : yes
cpuid level    : 11
wp        : yes
bogomips    : 4787.89
clflush size    : 64
power management:
processor    : 2
cpu family    : 6
model        : 37
stepping    : 2
microcode    : 0x9
cpu MHz        : 2400.000
physical id    : 0
siblings    : 4
core id        : 0
cpu cores    : 2
apicid        : 1
initial apicid    : 1
fpu        : yes
fpu_exception    : yes
cpuid level    : 11
wp        : yes
bogomips    : 4787.88
clflush size    : 64
power management:
processor    : 3
cpu family    : 6
model        : 37
stepping    : 2
microcode    : 0x9
cpu MHz        : 2400.000
physical id    : 0
siblings    : 4
core id        : 2
cpu cores    : 2
apicid        : 5
initial apicid    : 5
fpu        : yes
fpu_exception    : yes
cpuid level    : 11
wp        : yes
bogomips    : 4787.88
clflush size    : 64
power management:
I'm not too much expert on this stuff, what do you think aoubt it?
Thanks
Michele
Old   May 7, 2014, 08:48
M. C.
I edit previous post as was incomplete on cat /proc/cpuinfo command line
Old   May 7, 2014, 09:21
Giulio
seems ok, instead of using task manager, try with top and look at what it says.
Looking at the picture you posted first, I can see 4 processes running, ie one for each processor
To me task manager is showing a misleading info, probably that's a percentage calculated from the total CPU (made of 4 proc, so 25% is the amount associated to 1 proc)
top should tell info about every single processor, (works this way on my ubuntu), just try
Giulio
Old   May 7, 2014, 09:49
M. C.
Yes, you're right, task manager is telling me "lies", by prompting command line top, I can see all 4 cores are using 100% each.
Ciao e grazie!
Old   May 20, 2014, 09:20
Joachim Herb
jherb is on a distinguished road
In the top tool you can switch the settings of how the percentage is calculated (it is called IRIX mode), see the help page (press h):
  1,I       Toggle SMP view: '1' single/separate states; 'I' Irix/Solaris mode
If IRIX mode is turned off all processes are add up to 100 % whereas if IRIX mode is turned on the percentage is given per processor. I guess you can also change this in you task manager.
jherb is offline   Reply With Quote
Old   May 21, 2014, 15:55
M. C.
Thank you Herb for the suggestion, but I'm not able to do it. Anyway, I'm able to do it by typing "top".
Bye.
Michele
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 22:33
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Pre-Processing 4 August 2, 2016 06:24
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 09:53
problem in running parallel: ./Allrun: 62: shift: can't shift that many adambarfi OpenFOAM Running, Solving & CFD 10 May 11, 2015 10:31
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 04:50
