Sanity check: different nMoles in thermophysicalProperties similar results for 2 runs
Old   May 5, 2014, 18:50
Default Sanity check: different nMoles in thermophysicalProperties similar results for 2 runs
Andrew Somorjai
massive_turbulence is on a distinguished road
So I have this for my thermophsicalProperties for steam and I'm running it with the buoyantPimpleFoam hotRoom (slightly altered) case with nMoles 10 and another run with nMoles 100 and I get the same results?
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType      hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>;
pRef            101325;
mixture
    specie
        nMoles          10;
        molWeight       18.02;
    thermodynamics
        Cp              2.26;
        Hf              333700;
    transport
        mu              .000000001;
        Pr              .000000001;
Shouldn't the nMoles 100 case have a lower pressure and temperature at the same endTime? I figure having more of something would take more heat to heat up no?
I did change my 0/T file to this
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 273;
boundaryField
    wall
        type            zeroGradient;
    bottom
        type            compressible::turbulentHeatFluxTemperature;
        heatSource      power;// or flux
        q               uniform 20000;
        alphaEff        kappaEff;
        K               basicThermo;
        Cp              uniform 897;// steam
        value           uniform 673.5;
        KName             K;
massive_turbulence is offline   Reply With Quote
Old   May 6, 2014, 18:51
Andrew Somorjai
Nevermind, I think I figured it out. I had too many moles to begin with. After changing one of the systems (with less moles) to nMoles .01 there was definitely a big difference.
Wrong results in OpenFoam parallel runs visakhmg OpenFOAM Running, Solving & CFD 1 November 9, 2013 14:13
interrupt the simulation, check results, continue simulation soulsaver Phoenics 1 June 28, 2013 02:15
Wall function mesh vs y+=1 mesh gives similar results NickFSI STAR-CCM+ 0 March 12, 2013 06:35
Pause a simulation and check intermediate results AndMatri STAR-CD 2 October 19, 2012 06:59
Different results from similar quality cfx and ICEM meshes Nick R CFX 3 January 17, 2011 08:48
