Maximum number of iterations exceeded chtmultiregionsimpleFoam |
#21 | |
Vishnu
Rep Power: 7 ![]() |
Hi Peter,
Before setting the case, I need a clarification and solution for solid-fluid coupled interface creation. Quote:
Thank you, Vishsel Last edited by Vishsel; December 23, 2019 at 05:14. |
#22 |
Peter Hess
Rep Power: 17 ![]() |
Are you executing toposet before you separate or not?
#23 |
Vishnu
No I am not using topoSetDict.. Before that may i know purpose of the topoSet ?
If there are two solid region (s1 & s2) and one fluid region (f).. how to use it ? |
#24 |
Peter Hess
Well, you need to tell the splitMesh what is what.
Yes. You need to use topoSet. How do you generate the mesh? blockMesh? |
#25 |
Vishnu
No i have generated the mesh in Ansys workbench
And i have used fluent3DMeshToFoam command for conversion |
#26 |
Peter Hess
I see...
Did you use cutcell method? May be the Problem ist here? No, in this case you do not need topoSet! In the case you uploaded, in regionProberties there are Just two regions by the way. You need to add all regions by name there... Meshing and split regions from ansys Last edited by peterhess; December 26, 2019 at 13:21. |
#27 |
Pu Gong
Rep Power: 8 ![]() |
#28 |
Rep Power: 6 ![]() |
I have a similar issue. I run my calculation (one fluid (water) and two solids (pipe and soil)) on OF6 with chtMultiRegionFoam and with Euler and steady state I have the problem of negative initial temperatures or exceeded number of maximum iterations after certain timesteps. Depending on the settings of pressure it works fine for 500-2000 seconds, later it crashes.
I tried to use the bcs you mentioned Peter, but it is still not working. The mesh I checked already and it seems to be fine to me. In OF7 the same case is working without any error, but the timeoutput seems to be wrong. My fluid is flowing with 1m/s, but after 100 seconds it advanced in the pipe only a few centimeters and not 100 meters as it should do. I still believe the solution is hidden in the boundary conditions of pressure, but so far I could not figure out how to solve it. Could you be so kind and have a look at my case @Peterhess? Thank you in advance! |
#29 |
Derek Mitchell
Rep Power: 13 ![]() |
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
buoyantSimpleFoam and watertank | Tobi | OpenFOAM Running, Solving & CFD | 100 | December 18, 2022 08:15 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
