Foam fatal io error: cannot find file
Like Tree7Likes
Old   June 1, 2014, 11:41
starter
sihaqqi is on a distinguished road
Dear Bruno
Many thanks for your efforts. I removed last time step to check again at 0.1008569 and same thin happened. Also I tried with 0.1008569 and 0.100857 and I got the error as double scalar. I have attached the file you asked for. Log file is 203MB so after compression, it is still big enough and cannot be attached. However tomorrow I shall try to see in my Uni what other compression software we have. If I have something which can compress more, I shall reattach.
Best Regards
Imad
sihaqqi is offline   Reply With Quote
Old   June 2, 2014, 16:52
Retired Super Moderator
Bruno Santos
Hi Imad,
Hopefully I've figured out what the problem is! And it's one of those really annoying ones at that...
OK, in post #16 you have this:
Time = 0.1011976
It has 7 significant digits.
Then in post #18 you have the following details:
  1. Quote:
    Originally Posted by sihaqqi View Post
    No such time step as 0.101057 exists anywhere. Last time step I have in all processors is 0.1010569.
    The solver is asking for a time folder with 6 significant digits. But the existing folder has got 7 digits.
  2. Quote:
    Controldict contents are
    deltaT          1e-7;
    timePrecision   6;
    The defined precision in "controlDict" is 6 digits.
In the file list you attached in the previous folder you also have a lot of time folders with 7 digits. This apparently is because you have a deltaT of 1e-7, which means that sooner or later you're going to at least need 7 significant digits.
In addition, the file list you provided does not follow to a fixed deltaT, which I assume is because you used "writeControl clockTime" in the first run, which lead to the time folders you have at this moment.
The solution should be crazy simple: edit the file "system/controlDict" and change the timePrecision entry to 7 or 8 or even 9.
I do write every once in a while here on the forum that every single detail, no matter how insignificant if may seem, is a lot more important to OpenFOAM than we might want to believe!
Best regards,
Bruno
ejwaxxy likes this.
Old   June 4, 2014, 23:59
starter
Dear Bruno
I did not come back earlier because I have modified my controlDict and am waiting for simulations to run so that I can give you some sort of feedback. Still I am waiting. As soon as I see everything is okay which I expect it to be like you do, I shall advise.
Thanks again
Best Regards
Imad
Old   June 5, 2014, 02:05
starter
Hi Bruno
I am experiencing same error.
cannot find file
[210]
[210] file: /scratch/director674/shaqqi/tee/LES/75_original/processor210/0.100857/p at line 0.
[210]
[210]     From function regIOobject::readStream()
error continues for many processors like this
Also, log file ends in
"e533.27255"
"e541.5558"
"e548.5864"
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
sigFpe : Floating point exception trapping - not supported on this platform
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0.100857
Reading field p
Old   June 6, 2014, 16:02
Bruno Santos
Hi Imad,
A few questions:
  1. What is the content of the "system/controlDict" file you used for this latest output?
  2. Which are the latest time folders that are present in the "processor*" folders?
  3. What is the content of the file "uniform/time" that is in the latest time folder, in "processor0"?
    For example, if the latest time folder is "0.1008569", then what's inside the file "processor0/0.1008569/uniform/time"?
By the way, when posting code, file contents and so on, please use the "[CODE]" markers, as explained here: Posting code and output with [CODE]
Best regards,
Bruno
Old   June 8, 2014, 08:19
starter
Hi Bruno
controlDict contents are
application     pisoFoam;
startFrom       latestTime;
stopAt          endTime;
//stopAt          nextWrite;
endTime         5e-1;
deltaT          1e-7;
writeControl    timeStep;
//writeControl    clockTime;
writeInterval   2000;
purgeWrite      10;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  1;
        fields
            p
        probeLocations
         (0.036 2.000 0)
         (0.036 2.400 0)
            (0.036 2.600 0)
            (0.036 2.700 0)
            (0.036 2.798 0)
         (0.100 2.798 0)
         (0.300 2.798 0)
         (0.500 2.798 0)
         (1.000 2.798 0)
            (1.500 2.798 0)
         (2.000 2.798 0)
         (2.500 2.798 0)
         (3.000 2.798 0)
         (3.500 2.798 0)
         (4.000 2.798 0)
         (4.500 2.798 0)
         (-0.100 2.798 0)
         (-0.300 2.798 0)
         (-0.500 2.798 0)
         (-1.000 2.798 0)
            (-1.500 2.798 0)
         (-2.000 2.798 0)
         (-2.500 2.798 0)
         (-3.000 2.798 0)
         (-3.500 2.798 0)
         (-4.000 2.798 0)
         (-4.500 2.798 0)
    fieldAverage1
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
                mean        on;
                prime2Mean  on;
                base        time;
    surfaceSampling
        // Sample near-wall velocity
        type surfaces;
        // Where to load it from (if not already in solver)
        enabled         true;
        interpolationScheme cellPoint;
        surfaceFormat vtk;
        // Fields to be sampled
        fields
            U
        surfaces
            nearWall
                type            patchInternalField;
                patches         ( lowerWall );
                distance        1E-6;
                interpolate     true;
                triangulate     false;
Answer 2: Latest time step is 0.1008569
Answer 3:
Last time step uniform/time contents are below
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "0.1008569/uniform";
    object      time;
value           0.100857;
name            "0.1008569";
index           182000;
deltaT          1e-07;
deltaT0         1e-07;
Do you think if I change all time files manually and write value as 0.1008569 instead of 0.100857, should it work. Is there any command in linux which can change all these files with this value simultaneously as there are 1200 processors i.e., if it is going to be of help.
Thanks for your efforts and time.
Regards
Imad
Old   June 8, 2014, 09:03
Bruno Santos
Hi Imad,
I strongly advise you not to manually modify the time information in the time-related folders and files. Specially because you're using the time averaging procedure.
Edit the file "system/controlDict" and change this line:
timePrecision   6;
To this:
timePrecision 8;
or to this:
timePrecision 9;
Best regards,
Bruno
Old   June 8, 2014, 10:03
starter
Thanks Bruno
I apologize, I made writePrecision as 8 but not timePrecision by mistake. Anyways, I have corrected it. Hopefully it should work. I shall update you as soon as simulations run.
Best Regards
Imad
Old   June 8, 2014, 23:37
starter
Dear Bruno
Thanks, it has worked.
Best Regards
Imad
wyldckat likes this.
Old   July 29, 2014, 10:44
starter
Dear Bruno
Best Regards
Imad
Dear Bruno,
With reference to my question at link at
http://www.openfoam.org/mantisbt/view.php?id=1355#c3178
I will let that question at openfoam.org stay because I need to know why the software does not write more time steps after deleting the different time step. If we together figure out a way to solve it, I shall close the query myself. I know that solving all my questions is not your responsibility but in fact people like you take out your time to guide us.
I have posted the same question with more description at the link
http://www.cfd-online.com/Forums/ope...tml#post503586
If you can just go through it and advise, it would be great as it can save a lot of time. For your information, my job scheduler does not provide any warning as you mentioned. I use OpenFOAM 2.1.1. I cannot find "adjustTimeStep".
Regards
Imad
Old   August 16, 2014, 13:50
Bruno Santos
Hi Imad,
I've answered your question in the other thread. As for the last statement on this post above:
It's explained in the User Guide: http://www.openfoam.org/docs/user/controlDict.php - and demonstrated in several tutorials.
You can find all tutorials that use this feature by running this command:
find $FOAM_TUTORIALS -name controlDict | xargs grep -sl "adjustTimeStep"
For more information on how to search for more information in files present in OpenFOAM: http://openfoamwiki.net/index.php/In...hing_for_files
Best regards,
Bruno
afshindpe likes this.
Old   March 20, 2015, 04:43
Default cannot find file ....buoyantBoussinesqPimpleFoam/hotcy/hotcylinderm/0/T at line 0
  #32
Diana
diananilminikumari is on a distinguished road
Dear all,
I was trying to simulate flow through a cylinder.
After run the blockMesh , I have run buoyantBoussinesqPimpleFoam.
but it gave the error,
-> FOAM FATAL IO ERROR:
cannot find file
file: /home/diana/OpenFOAM/diana-2.3.0/run/tutorials/heatTransfer/buoyantBoussinesqPimpleFoam/hotcylinderm/0/T at line 0.
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Since I'm new in OpenFoam it is difficult to find why this is happening . please kind to help me
diananilminikumari is offline   Reply With Quote
Old   March 20, 2015, 05:05
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
It looks the T file does not exist in the 0 folder of your case. This is file needed to read the boundary conditions for the temperature fields and the values of temperature. Some tutorials in OpenFOAM-2.3.0 contain T.org which you can use a template for your problem.
Regards,
Franjo
Originally Posted by diananilminikumari View Post
Dear all,
cannot find file
FOAM exiting
niran likes this.
franjo_j is offline   Reply With Quote
Old   March 24, 2015, 00:59
Diana
Regards,
Franjo
Thank you very much, for your information and I got it .
Old   July 3, 2016, 23:16
Sumit
sumo793 is on a distinguished road
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for rotatingWall1
file: /home/sumit/OpenFOAM/sumit-3.0.1/run/tutorials/incompressible/simpleFoam/generator/0/U.boundaryField from line 26 to line 75.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209.
FOAM exiting
rotatingWall2
type fixedValue;
value uniform (0 0 0);
origin (0 0 0);
axis (1 0 0);
omega 83.73;
rotatingWall3
type fixedValue;
origin (0 0 0);
axis (1 0 0);
omega 83.73;
rotatingWall1
type fixedValue;
origin (0 0 0);
axis (1 0 0);
omega 83.73;
stuck at this error from few days....any solution
sumo793 is offline   Reply With Quote
Old   July 4, 2016, 05:43
Antimony is on a distinguished road
My guess, without looking at the entire U file, is that you are missing a ; and/or a } somewhere.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   July 4, 2016, 05:51
Sumit
i will check....thanks
Old   November 24, 2016, 04:09
Niranjan Prabhu
niran is on a distinguished road
i am facing the same problem
Reading waveProperties
cannot find file
file: /home/user/OpenFOAM/user-2.4.0/run/waveFlume2/constant/waveProperties at line 0.
how to slove this problem
i am running wave2foam tutorial waveFlume
niran is offline   Reply With Quote
Old   January 5, 2017, 14:14
Aditya Patil
Aditya Patil is on a distinguished road
OpenFOAM for Windows 16.06 (v2)
Aadhi@Aditya /cygdrive/c/OpenFOAM/Aadhi-3.0.x/run
$ tutorials/incompressible/icoFoam/elbow_tri
-bash: tutorials/incompressible/icoFoam/elbow_tri: Is a directory
$ fluentMeshToFoam.exe elbow.msh
| \\ / O peration | Version: 3.0.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
|* OpenFOAM for Windows 16.06 (v1) *|
|* Built by CFD Support, www.cfdsupport.com (based on Symscape). *|
Build : 3.0.x-ac3f6c67e02f
Exec : C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-3.0.x\platforms\cygwin64mingw-w64DPInt32Opt\bin\fluentMeshToFoam.exe elbow.msh
Date : Jan 05 2017
Time : 18:11:14
Host : "ADITYA"
PID : 3904
Case : C:/OpenFOAM/Aadhi-3.0.x/run
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
cannot find file
file: C:/OpenFOAM/Aadhi-3.0.x/run/system/controlDict at line 0.
FOAM exiting
Aditya Patil is offline   Reply With Quote
Old   December 14, 2017, 18:17
alix cattermole
alixcattermole is on a distinguished road
I am trying to import a mesh from netgen to openfoam and getting the same problem you had when i use the command netgenNeutralToFoam.
How did you manage to get around this error?
My error -->FOAM FATAL IO ERROR
cannot find file
file: /home/ofuser/workingDir/openfoam-v1706/system/controlDict at line 0
I am in the openfoam-v1706 working directory when i do this.
Thanks.
alixcattermole is offline   Reply With Quote
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
