Temp. difference in cold flow compression/expansion SprayEngineFoam with layered A/R
Old   April 29, 2014, 16:26
Default Temp. difference in compression/expansion SprayEngineFoam with layered A/R
lucasal is on a distinguished road
Hello all,
I am currently running a simulation with sprayEngineFoam by using a simple box with layered addition removal as described by Marco in the post "engineMesh with layered addition removal".
First, I would like to mention that there is a bug in the pEqn.H used by sprayEngineFoam. There is a mismatch of unity of measures when operating surfaceScalarField phiHbyA, so line 55 of pEqn.H should be modified as
(fvc::interpolate(rho*HbyA) & mesh.Sf())
At the moment, I am simulating only compression/expansion, starting from -180°CA (BDC) to +180°CA (next BDC).
What I noticed is that temperature and pressure are not specular respect to TDC, e.g. at -50°CA during compression temperature(640K) and pressure are substantially higher than at +50°CA during expansion (T=285K!!).
From theory they should be the same, since neither combustion nor fuel injection occur.
I attach the thermophysicalProperties and fvSolution files.
Has anybody noticed these P and T behaviours with layered A/R and engineMesh motion?
I was wondering if there could be an issue in the meshPhi flux that is not correctly computed expecially when new cells are added during expansion.
Can anybody help me? Thanks a lot!
Luca
lucasal is offline   Reply With Quote
layereda/r, sprayenginefoam, temperature difference
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
