Derivatives wrt Temperature
Old   April 24, 2014, 19:33
Default Derivatives wrt Temperature
Deepak Kalaikadal
kalaikdr is on a distinguished road
How do I calculate derivative of a fluid property wrt temperature, like d(rho)/dT or d(viscosity)/dT?
I am working on heat transfer in two phase systems where temperature gradients create vast differences in properties.
Are there schemes to calculate these derivatives? I could find only divergence, laplacian and grad schemes. How do i incorporate a new discretization scheme for a derivative like above? I am currently using interFOAM with temeperature incorporated!
Thanks!
kalaikdr is offline   Reply With Quote
Old   April 25, 2014, 05:19
chriss85 will become famous soon enough
Thanks!
You might have to extend the thermophysical model that you're using, to provide a function that calculates this derivative. Then you can use it in the equation you are solving. Depending on the model this can be an analytical or numerical derivative.
chriss85 is offline   Reply With Quote
Old   June 5, 2014, 15:19
Deepak Kalaikadal
Thank you Chriss. But I ended up giving a constant value for the derivative. It was a very small magnitude anyway.
discretization schemes, temperature derivatives
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Can we have access temperature derivatives??? behrang2009 Fluent UDF and Scheme Programming 0 July 29, 2010 20:21
