SpalartAllarmasIDDES LES model
Old   April 23, 2014, 20:24
Default SpalartAllarmasIDDES LES model
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
Hope you all are doing good.
I was trying to run a simulation for inertial flow using LES turbulence model. To capture the near wall physics and as a requirement of LES, I had to chose the mesh such that y+1 ~1. But for my case, it becomes too expensive in computational time to be feasible.
I was looking other approaches and found DES might work well for my case. I could not get thorough idea how to use SpalartAllarmasIDDES LES model, I mean what i need to change from LES setup. What I understand is:
1. I need to put RASproperties and LESporperties in constant folder
2. need to put LESModel as SpalartAllmarasIDDES for LES and SpalartAllmaras for RANS.
3. need to put SpalartAllmarasIDDES coefficents.
What about the boundary conditions? How could I use two type of boundary condition for RANS and LES at the same time?
Is there any y+ restrictions?
Can anyone tell me the steps I should follow for using SpalartAllmarasIDDES turbulence model? I would appreciate that.
Thanks
MMMN
mmmn036 is offline   Reply With Quote
Old   April 23, 2014, 21:01
Eric Robertson
msuaeronautics is on a distinguished road
This only requires the initialization of the turbulent viscosity (nuSgs) and the Spalart-Allmaras variable (nuTilda), as is the case with DDES and the RANS SA model.
You should pick nuSgs based on your desired turbulent viscosity ratio, while I believe nuTilda should probably be about 3 or 5 times nuSgs.
msuaeronautics is offline   Reply With Quote
LES Filter in Smagorinsky model on inhomogenous grids Ivan Main CFD Forum 1 October 25, 2012 12:30
Implementation of wall model to LES saeedi Main CFD Forum 3 August 24, 2012 15:51
documentation of LES model: oneeqeddy MacGyver OpenFOAM Running, Solving & CFD 1 July 16, 2012 10:09
Uregent LES model ck3 FLUENT 6 June 5, 2012 00:30
Implementing a new LES Model in OpenFoam fs82 OpenFOAM 6 October 13, 2009 10:58
