Uncovered faces found. On master: 0 on slave: 1749
Old   April 21, 2014, 11:20
Post Uncovered faces found. On master: 0 on slave: 1749
sam.ho is on a distinguished road
I have overlapGgi between turbine Impeller(ROTORY) and Downstream(STATIONARY)
When i run the case I am finding the following error
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_21.04.2014$ transonicMRFDyMFoam
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
Build  : 1.6-ext
Exec   : transonicMRFDyMFoam
Date   : Apr 21 2014
Time   : 19:26:32
Host   : BMH301562
PID    : 1795
Case   : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_21.04.2014
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh staticFvMesh
    From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const
    in file /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 544
--> FOAM FATAL ERROR:
Found uncovered faces for GGI interface IFC1_IMP_TO_UPS/IFC2_IMP_TO_DWS
This is an unrecoverable error. Aborting.
    From function void overlapGgiPolyPatch::calcPatchToPatch() const
    in file meshes/polyMesh/polyPatches/constraint/overlapGgi/overlapGgiPolyPatchGeometry.C at line 186.
FOAM aborting
Aborted (core dumped)
Note : No of faces on slave patch = 1794
Kindly help me how to resolve this uncovered faces problem ?
sam.ho is offline   Reply With Quote
Old   October 29, 2019, 02:48
Bidesh Sengupta
BSengupta is on a distinguished road
Did you manage to solve this problem? I am facing exactly same issue.
BSengupta is offline   Reply With Quote
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
