Defining multiple regions in MRFsimpleFoam
Old   April 21, 2014, 02:26
Default Defining multiple regions in MRFsimpleFoam
Mohammed Ameenuddin
ameen@cfd is on a distinguished road
Hello everyone,
I am working on centrifugal pump. I have generated the mesh in GridPro and converted it into openfoam. I have generated three fluid regions (say fluid1,fluid2 & fluid3) within the domain. The fluid1 (rotating) is the region surrounding the rotor and fluid2&fluid3 (non rotating) are near the outer boundary (outer casing). These regions are written in cellzone files generated after conversion.
My query is,
1. Will it be sufficient to define fluid1 (rotating) in fvoptions file or do i need to define the other regions as well. If yes then how can i do it.
2. If i donot define the non rotating cellzone will the solver consider it while solving. figure4_fluidregion_1.jpg
Thank you.
ameen@cfd is offline   Reply With Quote
Old   April 21, 2014, 09:46
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Only rotating region has to be defined in fvOptions file.
You might want to take a look at incompressible/simpleFoam/mixerVessel2D tutorial.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   April 22, 2014, 05:39
Mohammed Ameenuddin
Thank you Fumiya Nozaki, that was quite helpful. But that arises few more doubts.
1. Isn't it necessary to define relative velocity for the rotating parts. But as I can see in the tutorial there is no relative velocity defined. How does this work.
2. The other thing is I tried to solve my problem as per tutorial, but when I tried standard K-epsilon model my solution was giving me this error.
Time = 1.4
smoothSolver: Solving for Ux, Initial residual = 1.47848e-23, Final residual = 1.47848e-23, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 1.78189e-22, Final residual = 1.78189e-22, No Iterations 0
smoothSolver: Solving for Uz, Initial residual = 1.33499e-21, Final residual = 1.33499e-21, No Iterations 0
GAMG: Solving for p, Initial residual = 5.54095e-09, Final residual = 5.54095e-09, No Iterations 0
time step continuity errors : sum local = 1.3739e+119, global = -7.70269e+101, cumulative = -7.70269e+101
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 void Foam::multiply<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
But again when I used realizableKE this error didnt occur and is running. Is there any specific reason for it.
Thank you.
Old   April 22, 2014, 10:20
fumiya's Avatar
Fumiya Nozaki
1. I think this document might clear up your doubts (page 17):
http://www.tfd.chalmers.se/~hani/kur...inery-OFW7.pdf
2. The kEpsilon model is used in this tutorial:
https://github.com/OpenFOAM/OpenFOAM.../RASProperties
Hope this helps,
fumiya
[Personal]
Old   April 26, 2014, 01:05
Mohammed Ameenuddin
Thank you for the information. I have implemented it to my problem and running quite well.
If there are any issues i'll post them again.
Old   April 28, 2014, 08:34
Mohammed Ameenuddin
Hello Fumiya, Thanks for your help I am able to run my problem. Though it seems, it would take lot of time to converge.
Mean time I was thinking if particle tracking with MRFSimpleFoam is possible or not. The fluid I considered is blood, so in order to calculate blood damage due to stresses I want to implement particle tracking. Can you suggest how can I actually implement it.
Thank you.
Old   May 6, 2014, 03:57
Default Convergence
Mohammed Ameenuddin
I have been running my simulations for over 10000 iterations but I am not able to achieve convergence even below 10^-4. Can anyone help me to sort out this issue.
Details.
I'm solving centrifugal pump containing 5.4 Million Hexa cells using MRFSimpleFoam.
I have attached my boundary condition files and fvschemes and fvsolutions files.
Kindly provide some feedback.
U_P_K_E_file.pdf
fvSchemes.pdf
fvSolutions.pdf
Thank you.
Old   May 9, 2014, 06:29
Mohammed Ameenuddin
Can anyone please help me regarding the convergence.
I have changed from kepsilon to kOmegaSST and tried even changing the under relaxation factors. I changed the scheme to upwind. Even then I am not able to reach convergence upto 10^-4.
Any suggestions. The geometry and P, U conditions is same as defined in above
postresidualplot.jpg.
gridpro, mrfsimplefoam, openfoam
[snappyHexMesh] multiple regions Tobi OpenFOAM Meshing & Mesh Conversion 56 March 29, 2020 05:53
blockCoupled solver for multiple regions benk OpenFOAM 2 February 13, 2014 23:35
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
defining epsilon for multiple partitions dlogue OpenFOAM Running, Solving & CFD 0 May 20, 2010 12:41
