April 20, 2014, 15:27 |
courant number explodes
Ali reza
Rep Power: 12 |
hello everyone
I am somehow new in openfoam please help me to solve the problem. I have a simulated a pipe which water is flowing in and I am using icoFoam solver the check mesh is here Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 96136 faces: 267065 internal faces: 246979 cells: 85674 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 85674 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology body 19650 19700 ok (non-closed singly connected) inlet 218 244 ok (non-closed singly connected) outlet 218 244 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0142294 0 -0.0151572) (0.0129588 0.0472016 0.0022) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (8.88725e-17 9.11711e-17 1.4754e-17) OK. Max cell openness = 2.45267e-16 OK. Max aspect ratio = 5.50297 OK. Minimum face area = 5.30557e-09. Maximum face area = 1.31635e-07. Face area magnitudes OK. Min volume = 1.66462e-12. Max volume = 3.77399e-11. Total volume = 1.09182e-06. Cell volumes OK. Mesh non-orthogonality Max: 20.6887 average: 5.3841 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.435615 OK. Coupled point location match (average 0) OK. Mesh OK. End here I put fvsolution and fv schemes Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; } laplacianSchemes { default none; laplacian(nu,U) Gauss linear orthogonal; laplacian((1|A(U)),p) Gauss linear orthogonal; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default orthogonal; } fluxRequired { default no; p ; } Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 0; } Code:
Time = 0.004 Courant Number mean: 2.82932e+17 max: 1.79062e+21 |
May 5, 2014, 07:12 |
Luca
Rep Power: 13 |
I'm not an expert either with icoFoam.
You could look at the number of iterations for each field (u,p) to see which one diverges. Sometimes the problem is also caused by bad cells (even few can create big problems). Try run a checkMesh to see if the cells are all ok. If the mesh is ok you can try lowering the time-step to have a more stable problem. The question "why my simulation diverges?" is not an easy one to answer to, there could be tons of reasons... |
May 5, 2014, 08:38 |
ArathoN
Rep Power: 16 |
How did you compute the Courant number? remember to choose the smallest grid space when you'll calculate it. And try to change the solver in fvschemes or fvsolutions.
May 5, 2014, 10:42 |
#4 | |
Luca
Rep Power: 13 |
I think that such a rapid "explosion" is a mesh related problem. However you can also try to plot the value of Courant using the "Co" utility (just tipe "Co" in the prompt) and visualise it with paraView. This can help to understand where the Courant is exploded and to find the corresponding cells. This however works when you have "fisical" Co. Such an huge Co suggest the that U field is already (excuse me the technical term ) fucked up. |
May 5, 2014, 12:32 |
ArathoN
Rep Power: 16 |
I said computed because you need to set the time step in controldict, and to do so you need the grid spacing (better the smallest one) and a desired Co (i usually set it to 0.5 for stability). You can also try to limit the Max Co in controldict and see if it works.
I had a similar problem and i solved it by lowering the time step and changing the schemes. |
May 6, 2014, 06:40 |
Olivier
Rep Power: 18 |
hello,
You should add the 0/U and 0/p file if you want some help here. However, common mistake are: - bad scalling for your mesh see bounding box, here ~4 cm box is ok ? - bad BC and initial value. regards, Olivier |
May 7, 2014, 16:43 |
Ali reza
Rep Power: 12 |
thanks all of you for your attention
the mesh was made in gambit and scaled to mm in openfoam.I have put check mesh result and my time step as you can see is some thing about 0.001 and I have to decrease it to 0.00001 but it is really time consuming and it is not logically true in this case. these are my p and u boundary conditions. Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type groovyBC; valueExpression "vector(0,0.15-0.15*cos(2.5*pi*time()),0)"; gradientExpression "vector(0,0,0)"; fractionExpression "1"; value uniform (0 0 0); } outlet { type zeroGradient; } body { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type groovyBC; valueExpression "12000-2667*cos(2.5*pi*time())"; gradientExpression "0"; fractionExpression "1"; value uniform 0; } |
May 7, 2014, 17:01 |
Luca
Rep Power: 13 |
as Olivier pointed out: is it correct for the mesh to bee THAT SMALL?
Your overall domain is about 4cm large! The cells side are less than 1mm, is that correct? Your smallest cell is 1.66462e-12 m^3. With a 0.3 maximum inlet velocity 0.001s time step is not very small. |
May 8, 2014, 02:21 |
#9 |
Ali reza
Rep Power: 12 |
yes that is true but let me explain it maybe you have better idea.
I am working on a vein which is in mm scale and it needs 100000 mesh but I ran in in meter scale with no problem and the courant number even with 1 second time steps(not 0.001 or small ones) was less than 1 by IcoFoam solver however I have got the wrong answer for wall shear stress .By scaling the geometry to mm my wall shear stress come closer to fact nevertheless the courant number explode and I prefer to change my solver to PimpleFoam because I think that it lets me to define a courant number and it adjusts the time steps but I am not sure this is the right decision and I need to help me to solve the problem. thank you |
May 8, 2014, 14:31 |
#10 | |
ArathoN
Rep Power: 16 |
To calculate the time step you need to choose a Co number (less than 0.5 for LES or less than 1 generally, I usually tend to choose a given Co less than 0.5 for stability even if sometimes it isn't needed), then you need to see the smallest grid spacing possibly in all the 3 direction. Now you can calculate the time step needed and choose the smallest, obviously if the mesh is really small the time step will be really small. As a partially OT matter what is the smallest mesh/geometry than openfoam can study because i'm studying a channel with a height of 0.025m and a relative timestep of 2e-6 (Max Co 0.5). The solver has some problems especially if i use cyclic BCs with LES+pimplefoam (or even RANS+pimpleFoam). |
May 9, 2014, 12:48 |
#11 |
Ali reza
Rep Power: 12 |
I don't use now newtonian methods because of some special biological things and you can consider it as laminar, unsteady,newtonian flow but the dimensions are the same as things which you saw in check mesh part.
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 17:32 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Courant number and CFL number | snandish13 | STAR-CCM+ | 3 | January 7, 2013 05:14 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 19:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
