lift force problem with Flow around a cylinder |
April 11, 2014, 15:16 |
lift force problem with Flow around a cylinder in pimpleFoam
Rep Power: 13 |
Hi Foamers,
I am trying to simulate a flow around stationary cylinder on Re=20000. I am using the LES pimplefoam. However, every time I get the lift coefficient, the graph like shows in attachedy1.jpg In my opinion, this graph must have something wrong. But I try to use the high quality mesh, increase the tolerance and time step. It still get the graph like this. Could you give me some recommendations how could I get a stabilize cl graph? Thank you for your help. Best wishes Last edited by Scabbard; April 11, 2014 at 16:44. |
July 11, 2014, 08:31 |
cl graph
Manoj Jaiswal
Rep Power: 12 |
the graph you have obtained is correct . The cl is calculated for the entire body not for a particular point and so there would be karman vortex shedding and hence the lift would oscillate with time .
July 21, 2014, 05:19 |
#3 | |
Rep Power: 13 |
Thank you for your help. Best wishes, Scabbard |
Flow over 2D Cylinder, Laminar and Turbulent | Tsr63 | FLUENT | 5 | November 13, 2014 13:13 |
The resistance force of flow around vertical cylinder is high | hpkidmr | FLOW-3D | 1 | August 28, 2013 00:46 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 02:12 |
Thin foil analsis (sail) - Lift Coeff Problem | Kelvin | CFX | 3 | December 22, 2008 17:22 |
