strange problem with data
Old   April 11, 2014, 06:01
Default strange problem with data
seav is on a distinguished road
Hello FOMERS.
I dont know how to name my problem properly so it goes like this.
The problem is really strange for me. I want to make simple-test-checking simulation with setting and naming internal faces. I made simple blockMeshDict with vertices, blocks and patches. I created starting 0/ folder, system/ folder etc. and run my calculation without any problem. I was supprised when I was checking data collected.. 1st step at boundary conditions seems to be good, but then 2nd and whole steps after are red.
GEOMETERY : Its a small box in bigger box. attach 1, 2
1st STEP : Seems be ok. attach 3,4
PROBLEM : Red planes after calculation. attach 5
blockMeshDict:
FoamFile
	version	2.0;
	format	ascii;
	class	dictionary;
	object	blockMeshDict;
convertToMeters 0.001;
vertices
	(0 0 0) // 0
	(0 0 1) // 1
	(0 0 2) // 2
	(0 0 3) // 3
	(1 0 0) // 4
	(1 0 1) // 5
	(1 0 2) // 6
	(1 0 3) // 7
	(2 0 0) // 8
	(2 0 1) // 9
	(2 0 2) // 10
	(2 0 3) // 11
	(3 0 0) // 12
	(3 0 1) // 13
	(3 0 2) // 14
	(3 0 3) // 15
	(0 1 0) // 16
	(0 1 1) // 17
	(0 1 2) // 18
	(0 1 3) // 19
	(1 1 0) // 20
	(1 1 1) // 21
	(1 1 2) // 22
	(1 1 3) // 23
	(2 1 0) // 24
	(2 1 1) // 25
	(2 1 2) // 26
	(2 1 3) // 27
	(3 1 0) // 28
	(3 1 1) // 29
	(3 1 2) // 30
	(3 1 3) // 31
	(0 2 0) // 32
	(0 2 1) // 33
	(0 2 2) // 34
	(0 2 3) // 35
	(1 2 0) // 36
	(1 2 1) // 37
	(1 2 2) // 38
	(1 2 3) // 39
	(2 2 0) // 40
	(2 2 1) // 41
	(2 2 2) // 42
	(2 2 3) // 43
	(3 2 0) // 44
	(3 2 1) // 45
	(3 2 2) // 46
	(3 2 3) // 47
	(0 3 0) // 48
	(0 3 1) // 49
	(0 3 2) // 50
	(0 3 3) // 51
	(1 3 0) // 52
	(1 3 1) // 53
	(1 3 2) // 54
	(1 3 3) // 55
	(2 3 0) // 56
	(2 3 1) // 57
	(2 3 2) // 58
	(2 3 3) // 59
	(3 3 0) // 60
	(3 3 1) // 61
	(3 3 2) // 62
	(3 3 3) // 63
	(1 1 1) // 64
	(2 1 1) // 65
	(2 2 1) // 66
	(1 2 1) // 67
	(1 1 2) // 68
	(2 1 2) // 69
	(2 2 2) // 70
	(1 2 2) // 71
blocks
	hex (0 4 20 16 1 5 21 17) (3 3 3) simpleGrading (1 1 1)
	hex (4 8 24 20 5 9 25 21) (3 3 3) simpleGrading (1 1 1)
	hex (8 12 28 24 9 13 29 25) (3 3 3) simpleGrading (1 1 1)
	hex (1 5 21 17 2 6 22 18) (3 3 3) simpleGrading (1 1 1)
	hex (5 9 25 21 6 10 26 22) (3 3 3) simpleGrading (1 1 1)
	hex (9 13 29 25 10 14 30 26) (3 3 3) simpleGrading (1 1 1)
	hex (2 6 22 18 3 7 23 19) (3 3 3) simpleGrading (1 1 1)
	hex (6 10 26 22 7 11 27 23) (3 3 3) simpleGrading (1 1 1)
	hex (10 14 30 26 11 15 31 27) (3 3 3) simpleGrading (1 1 1)
	hex (16 20 36 32 17 21 37 33) (3 3 3) simpleGrading (1 1 1)
	hex (20 24 40 36 21 25 41 37) (3 3 3) simpleGrading (1 1 1)
	hex (24 28 44 40 25 29 45 41) (3 3 3) simpleGrading (1 1 1)
	hex (17 21 37 33 18 22 38 34) (3 3 3) simpleGrading (1 1 1)
	hex (21 25 41 37 22 26 42 38) (3 3 3) simpleGrading (1 1 1)
	hex (25 29 45 41 26 30 46 42) (3 3 3) simpleGrading (1 1 1)
	hex (18 22 38 34 19 23 39 35) (3 3 3) simpleGrading (1 1 1)
	hex (22 26 42 38 23 27 43 39) (3 3 3) simpleGrading (1 1 1)
	hex (26 30 46 42 27 31 47 43) (3 3 3) simpleGrading (1 1 1)
	hex (32 36 52 48 33 37 53 49) (3 3 3) simpleGrading (1 1 1)
	hex (36 40 56 52 37 41 57 53) (3 3 3) simpleGrading (1 1 1)
	hex (40 44 60 56 41 45 61 57) (3 3 3) simpleGrading (1 1 1)
	hex (33 37 53 49 34 38 54 50) (3 3 3) simpleGrading (1 1 1)
	hex (37 41 57 53 38 42 58 54) (3 3 3) simpleGrading (1 1 1)
	hex (41 45 61 57 42 46 62 58) (3 3 3) simpleGrading (1 1 1)
	hex (34 38 54 50 35 39 55 51) (3 3 3) simpleGrading (1 1 1)
	hex (38 42 58 54 39 43 59 55) (3 3 3) simpleGrading (1 1 1)
	hex (42 46 62 58 43 47 63 59) (3 3 3) simpleGrading (1 1 1)
	hex (64 65 66 67 68 69 70 71) last_block (3 3 3) simpleGrading (1 1 1)
patches
	wall plate
		(64 65 66 67)
		(68 69 70 71)
		(64 68 71 67)
		(69 65 66 70)
		(68 69 65 64)
		(71 70 66 67)
	wall nate
		(0 4 20 16)
		(4 8 24 20)
		(8 12 28 24)
		(16 20 36 32)
		(20 24 40 36)
		(24 28 44 40)
		(32 36 52 48)
		(36 40 56 52)
		(40 44 60 56)	// end front
		(3 7 23 19)
		(7 11 27 23)
		(11 15 31 27)
		(19 23 39 35)
		(23 27 43 39)
		(27 31 47 43)
		(35 39 55 51)
		(39 43 59 55)
		(43 47 63 59)	// end back
		(0 1 17 16)
		(1 2 18 17)
		(2 3 19 18)
		(16 17 33 32)
		(18 19 35 34)
		(32 33 49 48)
		(33 34 50 49)
		(34 35 51 50)	// begin front - inlet
		(15 14 30 31)
		(14 13 29 30)
		(13 12 28 29)
		(31 30 46 47)	// begin back - outlet
		(29 28 44 45)
		(47 46 62 63)
		(46 45 61 62)
		(45 44 60 61)
		(51 55 54 50)
		(55 59 58 54)
		(59 63 62 58)
		(50 54 53 49)
		(54 58 57 53)
		(58 62 61 57)
		(49 53 52 48)
		(53 57 56 52)
		(57 61 60 56)	//end up plate
		(3 7 6 2)
		(7 11 10 6)
		(11 15 14 10)
		(2 6 5 1)
		(6 10 9 5)
		(10 14 13 9)
		(1 5 4 0)
		(5 9 8 4)
		(9 13 12 8)
	patch inlet
		(17 18 34 33)
	patch outlet
		(30 29 45 46)
	/*defaultFaces
		type empty;
		faces();
mergePatchPairs
controlDict:
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     icoFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.5;
deltaT          0.005;
writeControl    timeStep;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nu,U) Gauss linear orthogonal;
    laplacian((1|A(U)),p) Gauss linear orthogonal;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         orthogonal;
fluxRequired
    default         no;
    p               ;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
0/p:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    	inlet
        	type	fixedValue;
		value	uniform 3;
	outlet
        	type 	zeroGradient;
	nate
		type 	zeroGradient;
	plate
		type 	zeroGradient;
0/U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
	inlet
		type            fixedValue;
		value		uniform (0.368 0 0);
	outlet
		type 		zeroGradient;
	nate
		type 		zeroGradient;
	plate
		type		zeroGradient;
I am using OF 2.2.2 and ParaView-3.12
seav is offline   Reply With Quote
Strange Flamelet Generation Problem tar FLUENT 11 March 22, 2014 11:52
Problem in Interpolating data command shubham208011 FLUENT 6 July 15, 2013 09:18
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Anyone met this strange problem? Lee Siemens 1 June 7, 2005 04:15
