waveTransmissive Boundary condition for rho?
Old   April 7, 2014, 23:03
Default waveTransmissive Boundary condition for rho?
Daniel
dancfd is on a distinguished road
Hello Foamers,
I am trying to apply a non-reflective boundary condition to a transonic airfoil case in a C-grid. I figure I could use waveTransmissive on both inlet and outlet boundaries, since the inlet velocity changes angle as a function of time. However, when I run the case I get the following error in decomposePar:
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 30 the word 'rho'
file: /home/daniel/OpenFOAM/daniel-2.1.1/run/cases/mccroskey1982/14210_varFS/run1_janaf_wtall/0/rho::boundaryField::(inlet|topAndBottom|outlet)::fieldInf at line 30.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 91.
My BC for rho is attached. I tried changing "rho" to "1.3" on line 30 (which goes against my understanding of how this boundary condition works), but then I get the following error:
wrong token type - expected word, found on line 30 the doubleScalar 1.3
file: /home/daniel/OpenFOAM/daniel-2.1.1/run/cases/mccroskey1982/14210_varFS/run1_janaf_wtall/0/rho::boundaryField::(inlet|topAndBottom|outlet)::rho at line 30.
    From function operator>>(Istream&, word&)
    in file primitives/strings/word/wordIO.C at line 74.
I do not have the same problem for other scalars: p, omega, k, T, mut. Can anyone suggest why it might be happening for rho?
Thanks in advance,
Daniel
dancfd is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Radiation interface hinca CFX 15 January 26, 2014 18:11
Mixed/Robin boundary condition aaev OpenFOAM Bugs 2 December 15, 2011 15:03
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
