Weird transverse velocity in a channel
Old   April 7, 2014, 18:16
Question Weird transverse velocity in a channel
Daniele
dancoz87 is on a distinguished road
Hi foamers,
I've got a problem with the simulation of the flow in a channel of a rod bundle.
I have high residuals for momentum in transverse direction and I've found that in fact something goes wrong with that: instead of a flat, nil velocity along the channel axis (it is symmetric), I have a strange periodic behaviour (check attached plot).
The main flow looks sensible (and the residuals at the end are low), except for the sections where the peaks of transverse velocity are located: here the flow is totally unphysical (check y-velocity section).
I am using buoyantPimpleFoam (vers.2.2.0) with a maximum Co = 0,5.
I have tried different meshes, boundary conditions, lower timesteps... but nothing works.
I have even tried setting transverse velocity to zero and restart the run, unsuccessfully.
I will appreciate all your attempts to help me, thank you!
dancoz87 is offline   Reply With Quote
3D parabolic velocity profile for channel flow seetaratnam FLUENT 1 August 10, 2016 04:08
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 07:26
Friction velocity in Channel flow impecca OpenFOAM Post-Processing 2 April 11, 2014 02:33
How to make a UDF to have a velocity profile in a square channel Gigis Fluent UDF and Scheme Programming 8 January 13, 2013 23:20
weird velocity profile firavia FLUENT 12 November 9, 2012 07:54
