Airfoil with simpleFoam and kOmegaSST: high drag values?
Old   April 7, 2014, 16:02
Question Airfoil with simpleFoam and kOmegaSST: high drag values?
Marco C.
Tsiolkovsky is on a distinguished road
Hello FOAMers,
I am a beginner in OpenFOAM: I’ve learned the basics through some tutorials and I’ve been recently trying to obtain some good results from a 2D airfoil case.
I’m using simpleFoam with kOmegaSST turbulence model to simulate the flow around a NACA 2415 airfoil (Reynolds number approximately 3*10^6 and 8 degrees angle of attack) and I’m currently struggling to achieve nice results in terms of drag coefficient.
I can’t really understand where the error lies, so I’m asking for some help.
MESH:
Could this be the problem?: I built it using a Matlab code from https://www.hpc.ntnu.no/display/hpc/...l+Calculations
This script generates the blockMeshdict file you can find at the end of this post.
This is how the mesh looks like in Paraview:
BOUNDARY CONDITIONS:
As in the airfoil2d tutorial, I’m using freestream BC for U both at inlet and outlet, and obviously zero velocity condition on airfoil patch.
For p, freestreampressure at inlet/outlet and zerogradient on airfoil.
For k, freestream BC at inlet/outlet and kqRWallFunction on airfoil.
For omega, freestream BC at inlet/outlet and omegaWallFunction on airfoil.
For nut, calculated BC at inlet/outlet and nutkWallFunction on airfoil.
Boundary values for k and omega were taken from http://www.cfd-online.com/Wiki/Turbu...ary_conditions, using a turbulence intensity I=0.005 and turbulent length scale 0.05 (5% of airfoil chord).
FINALLY, THE RESULTS:
After 2000 iterations, i get the following results (this were the best I could get after many little changes in terms of BC and mesh):
lift coefficient Cl = 1.0307
drag coefficient Cd = 0.01679
I have the following experimental data from the famous Abbott-Von Doenhoff database:
Cl approximately 1
Cd around 0.010
As you can see, lift coefficient is good while drag coefficient is really high.
These values were the best I could get after some mesh/BC tuning: usally Cd values wander between 0.018 and 0.022.
Regarding y+, I’ve run yPlusRAS after the simulation and these are the results for the last timestep:
Patch 2 named airfoil y+ : min: 14.2581 max: 162.504 average: 107.005
Is this bad/good? I can't really say as I haven't found (yet) any advice on good y+ for kOmegaSST.
Thank you for your patience and for your help.
Down here you’ll find the complete case directory with all the files (it's just 120 kB)
https://www.dropbox.com/s/sm99dt8lq8...ACA2415_KW.tar
Thanks in advance,
Marco
Tsiolkovsky is offline   Reply With Quote
Old   April 7, 2014, 16:27
Pete Bachant
pbachant is on a distinguished road
Your BCs at the foil surface seem good for the mesh resolution, but for accurate drag prediction, you may want to get down to a y+ ~ 1. Then I believe you'd use these BCs:
k:
fixedValue;
uniform 1e-12;
nut:
nutUSpaldingWallFunction;
uniform $internalField; // or similar
pbachant is offline   Reply With Quote
Old   April 7, 2014, 18:44
Marco C.
k:
fixedValue;
uniform 1e-12;
nut:
Thank you for your reply!
I've just made a (very) quick test changing the mesh expansion rates to reach an average y+ ~ 3 and setting BCs as you suggested, but results don't seem to improve very much...
Old   April 18, 2014, 20:54
whophil is on a distinguished road
I don't have an answer about improving Cd values, but in the .tar file you posted, the 0/U file as well as the liftDir and dragDir in the system/forceCoeffs dictionary are pointing in the wrong directions.
The grid generated by blockMesh puts the airfoil in the x-z plane, while the velocity and lift/drag vectors are in the x-y plane.
whophil is offline   Reply With Quote
Old   April 18, 2014, 22:39
Dongyue Li
sharonyue is on a distinguished road
Sorry to hijack this thread. Could you tell me how to insert your pic in your main passage. I just can attach pic. Thanks
sharonyue is offline   Reply With Quote
Old   April 19, 2014, 04:47
Marco C.
Sorry, you're right. I forgot to mention that after building the mesh I rotate it using the command:
rotateMesh "(0 0 1)" "(0 1 0)"
After doing this the airfoil lies in the xy plane.
Old   November 21, 2018, 06:56
CFD
N.Ganesh is on a distinguished road
Hii,
Maybe, the Grid which you are using is not orthogonal to the airfoil surface. So make it orthogonal and give it a try, it may help you.
N.Ganesh is offline   Reply With Quote
airfoil, komegasst, simplefoam
SimpleFoam: High residuals after increase in Reynolds Number JasonG OpenFOAM Running, Solving & CFD 21 October 5, 2017 11:11
simpleFoam with kOmegaSST ilpaso OpenFOAM Running, Solving & CFD 11 April 7, 2014 07:12
simpleFoam kOmegaSST LowRe pressure divergence Pat84 OpenFOAM Running, Solving & CFD 2 August 12, 2013 18:42
OpenFOAM 2.x simpleFoam and kOmegaSST convergence and wall treatment gillimaniac OpenFOAM Running, Solving & CFD 6 August 1, 2013 02:36
drag coeff to high - kOmegaSST turbulence model RugbyGandalf OpenFOAM 5 February 22, 2011 03:35
