How to use MPPICFoam with turbulence effects on particle motion? |
#21 |
Huynh Phong Thanh
Rep Power: 13 ![]() |
Hi guys,
I also problem with kEpsilon model in DPMFoam OF2.2.x. I tried to add terms in scheme but it stills errors. Code:
--> FOAM FATAL ERROR: request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 6 ( phic_0 ((interpolate((((1|A(Uc))*cloudVolSUSu)|rhoc))&S)+(Dp*(g&S))) alphaPhic phic Dp alphacf ) Thanks |
#22 |
Huynh Phong Thanh
Hi all,
I solved the above problems by adding phic at inlet and outlet BC for k and epsilon k Code:
inlet_pipe { type turbulentIntensityKineticEnergyInlet; value $initialField; phi phic; alpha alphac; intensity 0.03; } Code:
outlet { type inletOutlet; phi phic; alpha alphac; inletValue $internalField; value $internalField; } Code:
inlet_pipe { type turbulentMixingLengthDissipationRateInlet; value $initialField; phi phic; alpha alphac; mixingLength 0.042; } Code:
Courant Number mean: 5.18008e-007 max: 0.0244965 Time = 2e-005 Evolving kinematicCloud Solving 3-D cloud kinematicCloud Cloud: kinematicCloud Current number of parcels = 0 Current mass in system = 0 Linear momentum = (0 0 0) |Linear momentum| = 0 Linear kinetic energy = 0 Rotational kinetic energy = 0 model1: number of parcels added = 0 mass introduced = 0 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) : patch inlet_pipe - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outside_wall_pipe - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch inside_wall_pipe_1 - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch symmetry_pipe - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch symmetry_2 - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outside_wall - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outlet_ambient - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch inside_wall_pipe_2 - escape = 0, 0 - stick = 0, 0 DILUPBiCG: Solving for Ucx, Initial residual = 1, Final residual = 1.25761e-009, No Iterations 2 DILUPBiCG: Solving for Ucy, Initial residual = 1, Final residual = 9.96601e-010, No Iterations 2 DILUPBiCG: Solving for Ucz, Initial residual = 1, Final residual = 1.65935e-006, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00719945, No Iterations 18 GAMG: Solving for p, Initial residual = 0.157115, Final residual = 0.00130879, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0174056, Final residual = 0.000154434, No Iterations 3 time step continuity errors : sum local = 1.30207e-007, global = -1.40036e-008, cumulative = -1.40036e-008 GAMG: Solving for p, Initial residual = 0.00302915, Final residual = 1.90974e-005, No Iterations 5 GAMG: Solving for p, Initial residual = 0.00119684, Final residual = 6.68533e-006, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000211614, Final residual = 7.64506e-007, No Iterations 5 time step continuity errors : sum local = 6.32305e-010, global = -7.29831e-011, cumulative = -1.40765e-008 DILUPBiCG: Solving for epsilon, Initial residual = 0.000435878, Final residual = 1.6674e-008, No Iterations 1 --> FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed available objects of type volVectorField are 3 ( Uc_0 Uc cloudVolSUSu ) From function objectRegistry::lookupObject<Type>(const word&) const The velocity Uc as the same Goldschmidt OF tutorial. I hope foamers give me a recommendation to solve problem. Thanks |
#23 |
Huynh Phong Thanh
Hi again,
Finally, I solved the problems that some BCs require phi and U but these conditions do not get parameter for phi, U because DPM solver is using Uc and phic, rhoc for continuous or fluid phase. Therefore, it should add phic and Uc in BCs. Here is the case https://www.cfd-online.com/Forums/at...1&d=1496850233 |
#24 |
Min Zhang
Rep Power: 9 ![]() |
I am wondering whether you could have a look at my post about MPPICFoam. Simulate particle/liquid flow in a converging geometry with MPPICFoam Thank you so much! |
dispersion model, mppicfoam |
UDF for multicomponent particle vaporization | Mohsin | Fluent UDF and Scheme Programming | 17 | January 27, 2021 02:57 |
Multiphase particle motion queries | siw | Main CFD Forum | 0 | February 14, 2012 10:00 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
