LES: subgrid-scale mixing rate
Old   March 24, 2014, 08:59
Default LES: subgrid-scale mixing rate
Alberto Cuoci
acuoci is on a distinguished road
Hello everybody,
I need to calculate the subgrid-scale mixing rate TauSGS in a LES simulation, which is defined in the following way:
TauSGS = 1 / sqrt ( 2 * Sij*Sij)
where Sij is the strain rate tensor (in 1/s), i.e.:
Sij = 0.5 * ( dvi/dxj + dvj/dxi)
where dvi/dxi is the derivative of j-th component of velocity with respect to the i-th coordinate
1. Do you know how I can calculate it in OpenFOAM?
2. Do you also know how I can distinguish if I am performing a RANS or a LES simulation? In other words, is there any function in the turbulenceModel class returning if this is a RANS or a LES?
Thank you very much in advance!
Alberto
acuoci is offline   Reply With Quote
Old   March 24, 2014, 18:10
Lieven
Lieven will become famous soon enough
Hi Alberto,
You can try something like:
volSymmTensorField S(dev(symm(gradU)));
volScalarField magS(sqrt(2.0)*mag(S));
volScalarField tau("tau",pow(2*magS*magS,-0.5));
I dind't try it but it might do the trick...
Cheers,
L
Lieven is offline   Reply With Quote
les model, strain rate, subgrid scale
reasonable mixing rate for C2H6 Oxygen mixture N. Schiepel CFX 0 September 12, 2008 05:57
how to do in dynamic subgrid sgs les model? aiya Main CFD Forum 2 September 15, 2006 02:45
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
Anisotropic subgrid model (LES) h.jordi Main CFD Forum 1 August 29, 2002 16:49
LES unsteady : Turbulent Mixing Layer Flav FLUENT 5 December 13, 1999 04:11
