March 21, 2014, 06:55 |
Divergence problem in interpasechangefoam
Baris (Heewa)
Rep Power: 13 |
Hi to all,
I am trying to simulate cavitation inside of nozzle. It is turbulent flow, used RNG k-epsilon turbulence model. My nozzle shape is attached. Upside is inlet (wider one) down side is outlet. I am using interphasechangeFoam ver2.1.1. I have just done following modification in U.Eqn to decrease the calculate nut as indicated in the paper of Coutier Delgosha (2003). Code:
dimensionedScalar rhoUnit("rhoUnit", dimDensity, 1.0); surfaceScalarField muEff ( "muEff", twoPhaseProperties->muf() + fvc::interpolate((Foam::pow((0.017-rho/rhoUnit),5)/Foam::pow((0.017-998),5)*(998-0.017)+ 0.017)*rho*turbulence->nut()) ); 0/U inlet ==> FixedValue HTML Code:
outlet= intletOutlet and tried pressureInletOutletVelocity; HTML Code:
inlet ==> zeroGradient Outlet==> fixedValues ==>1e5, 1e4...0 (gradully decreased until 0) and also for outlet i tried: fixedMeanValue HTML Code:
inlet ==>fixedValue outlet ==> tried fixedValue and inletOutlet wall ==>tried epsilonWallFunction/kqRWallFunction and zerogradient HTML Code:
inlet/outlet ==>calculated wall==>nutkWallFunction HTML Code:
divSchemes div(rhoPhi,U) Gauss linear; div(phi,epsilon) Gauss upwind; div(phi,k) Gauss upwind; div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss interfaceCompression; laplacianSchemes { default Gauss linear corrected; } snGradSchemes { default none; snGrad(pd) limited 0.5; snGrad(rho) limited 0.5; snGrad(alpha1) limited 0.5; } fluxRequired { default none; p_rgh; pcorr; alpha1; } HTML Code:
relaxationFactors { fields { } equations { "U.*" 0.7; "k.*" 0.5; "epsilon.*" 0.5; "p_rgh.*" 0.3; } Although i tried different BCS as indicated above always deltaT reached very low valuse and gave divergence floating point error as follows: HTML Code:
GAMG: Solving for p_rgh, Initial residual = 9.10213e-09, Final residual = 9.10213e-09, No Iterations 0 GAMG: Solving for p_rgh, Initial residual = 9.10213e-09, Final residual = 9.10213e-09, No Iterations 0 time step continuity errors : sum local = 2.80061e+06, global = -4.94029e-10, cumulative = 0.00804153 GAMG: Solving for p_rgh, Initial residual = 1.20034e-08, Final residual = 9.50047e-10, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 4.32284e-15, Final residual = 4.32284e-15, No Iterations 0 time step continuity errors : sum local = 994878, global = -2.11248e-10, cumulative = 0.00804153 PIMPLE: not converged within 50 iterations ExecutionTime = 1974.23 s ClockTime = 2002 s Courant Number mean: 6.58573e+06 max: 2.47105e+13 deltaT = 2.17834e-30 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 6.97175e-05 Time = 6.97175051e-05 [11] #0 Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&)[7] #0 Foam::error::printStack(Foam::Ostream&)[6] #0 Foam::error::printStack(Foam::Ostream&)[10] #0 Foam::error::printStack(Foam::Ostream&)[9] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int)[2] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [7] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [11] #1 Foam::sigFpe::sigHandler(int)[4] #0 Foam::error::printStack(Foam::Ostream&)[5] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [9] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [10] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [7] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 [0] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [5] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [9] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [11] #2 in "/lib/libc.so.6" [3] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [10] #2 [8] #0 Foam::error::printStack(Foam::Ostream&) in "/lib/libc.so.6" [7] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [6] #1 Foam::sigFpe::sigHandler(int) in "/lib/libc.so.6" [11] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #2 in "/lib/libc.so.6" [9] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libO in "/opt/openfoam211/platforms/penFOAM.so" [0] #1 linux64GccDPOpt/lib/libOpenFOAM.so" Foam::sigFpe::sigHandler(int)[1] #1 Foam::sigFpe::sigHandler(int) in "/lib/libc.so.6" [10] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [5] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [4] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [8] #1 Foam::sigFpe::sigHandler(int) in "/lib/libc.so.6" [2] #3 [7] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [7] #4 [3] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [3] #4 [11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [11] #4 in "/lib/libc.so.6" [5] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [6] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/lib/ in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 libc.so.6" [4] #3 [10] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [10] #4 in "/lib/libc.so.6" [1] #3 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [8] #2 in "/lib/libc.so.6" [0] #3 [2] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [2] #4 [11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [11] #5 [9] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [9] #4 in "/lib/libc.so.6" [6] #3 [3] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [3] #5 [4] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [4] #4 [7] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [7] #5 in "/lib/libc.so.6" [8] #3 [5] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [5] #4 [9] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [9] #5 [11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [11] #6 __libc_start_main[0] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [0] #4 [1] in "/home/yusuke/OpenFOAM/yusuke-2.1[3] in "/home/yusuke/OpenFOAM/yusuke.1/platforms/linux64GccDPOpt/bin/RNGinterP-2.1.1/platforms/linux64GccDPOpt/bin/RhaseChangeFoam" NGinterPhaseChangeFoam" [1] #4 [3] #6 __libc_start_main [2] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [2] #5 [6] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [6] #4 [10] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [10] #5 in "/lib/libc.so.6" [11] #7 [7] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [7] #6 __libc_start_main in "/lib/libc.so.6" [3] #7 [4] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [4] #5 [9] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [9] #6 __libc_start_main[6] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [6] #5 in "/lib/libc.so.6" [7] #7 [1] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [1] #5 [2] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [2] #6 __libc_start_main [10] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [10] #6 __libc_start_main[5] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [5] #5 [8] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [8] #4 in "/lib/libc.so.6" [2] #7 [11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [VENUS:26554] *** Process received signal *** [VENUS:26554] Signal: Floating point exception (8) [VENUS:26554] Signal code: (-6) [VENUS:26554] Failing at address: 0x3e8000067ba [VENUS:26554] [ 0] /lib/libc.so.6(+0x33af0) [0x7f17f47d3af0] [VENUS:26554] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7f17f47d3a75] [VENUS:26554] [ 2] /lib/libc.so.6(+0x33af0) [0x7f17f47d3af0] [VENUS:26554] [ 3] RNGinterPhaseChangeFoam() [0x4a8442] [VENUS:26554] [ 4] RNGinterPhaseChangeFoam() [0x4b74fd] [VENUS:26554] [ 5] RNGinterPhaseChangeFoam() [0x435358] [VENUS:26554] [ 6] /lib/libc.so.6(__libc_start_main+0xfd) [0x7f17f47bec4d] [VENUS:26554] [ 7] RNGinterPhaseChangeFoam() [0x42b849] [VENUS:26554] *** End of error message *** in "/lib/libc.so.6" [10] #7 [0] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [0] #5 in "/lib/libc.so.6" [9] #7 [3] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [VENUS:26546] *** Process received signal *** [VENUS:26546] Signal: Floating point exception (8) [VENUS:26546] Signal code: (-6) [VENUS:26546] Failing at address: 0x3e8000067b2 [VENUS:26546] [ 0] /lib/libc.so.6(+0x33af0) [0x7ff896532af0] [VENUS:26546] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7ff896532a75] [VENUS:26546] [ 2] /lib/libc.so.6(+0x33af0) [0x7ff896532af0] [VENUS:26546] [ 3] RNGinterPhaseChangeFoam() [0x4a8483] [VENUS:26546] [ 4] RNGinterPhaseChangeFoam() [0x4b74fd] [VENUS:26546] [ 5] RNGinterPhaseChangeFoam() [0x435358] [VENUS:26546] [ 6] /lib/libc.so.6(__libc_start_main+0xfd) [0x7ff89651dc4d] [VENUS:26546] [ 7] RNGinterPhaseChangeFoam() [0x42b849] [VENUS:26546] *** End of error message *** [1] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam" [1] #6 __libc_start_main I dont know what i can do .Please can someone guide and tell me some new ways.. Thanks in advance. B |
March 22, 2014, 04:40 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Baris,
After a very quick read and looking at the images, my guess is that the problem is related to a bad mesh or due to insufficient resolution or big changes in resolution near the wall. To understand what I mean, have a look into this blog post of mine: OpenFOAM: Interesting cases of bad meshes and bad initial conditions Best regards, Bruno
March 22, 2014, 05:26 |
hi
Baris (Heewa)
Rep Power: 13 |
Dear Bruno,
Thanks so much for your reply. About mesh, i checked it that seems OK as follows: HTML Code:
Mesh stats points: 654382 faces: 1596014 internal faces: 1412748 cells: 471322 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 410213 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 61109 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology Bounding box wall 182766 183793 ok (non-closed singly connected) (-0.006 -0.008 -2.71051e-20) (0.00194 0.007 0.00194) outlet 100 121 ok (non-closed singly connected) (0 -0.008 0) (0.00194 -0.008 0.00194) inlet 400 451 ok (non-closed singly connected) (-0.006 0.007 0) (0.00194 0.007 0.00194) Checking geometry... Overall domain bounding box (-0.006 -0.008 -2.71051e-20) (0.00194 0.007 0.00194) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.22526e-14 -1.42534e-17 -2.50737e-15) OK. Max cell openness = 2.06795e-16 OK. Max aspect ratio = 2.5 OK. Minumum face area = 3.75e-11. Maximum face area = 1.6e-07. Face area magnitudes OK. Min volume = 7.03125e-16. Max volume = 6.4e-11. Total volume = 1.37934e-07. Cell volumes OK. Mesh non-orthogonality Max: 29.0546 average: 10.3431 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.6129 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 5e-06 0.0004 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.821136 average: 13.565 Cell determinant check OK. Thanks. B. |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 06:03 |
Meshing and divergence problem | ghost | FLUENT | 9 | February 5, 2010 13:24 |
divergence problem | vincent | FLUENT | 3 | August 3, 2006 16:44 |
strange divergence when solving multiphase problem | tanghao | FLUENT | 2 | July 27, 2006 20:47 |
divergence problem | Ayyappan.T | FLUENT | 2 | May 16, 2005 13:10 |
