trying out solidBodyMotionSolver with dynamicFvMesh |
March 20, 2014, 06:42 |
Rep Power: 12 |
Hi Foamers,
I have the case of rotating fan, which I simulated using cyclicAMI(cylinder) around the fan and motion of the cyclicAMI was moving with respect to the domain like propeller tutorial I was not able to predict forces accurately (other parameters were match with experiments). so I am trying another approach I am using dynamicMotionSolverFvMesh my pointDisplacement file. I am getting FPE, when I did unset FOAM_SIGFPE and started the solver after a while forces on my patch "Imperial.*" keep decreasing and /0 happens. I presume the diffusivity solver should take care of the mesh motion but it isn't I have kept Courant number 0.2 (for the AMI case Courant number 1-2 was used) Any help would be appreciated Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class pointVectorField; location "0.01"; object pointDisplacement; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { "ImperialBlade.*" { type solidBodyMotionDisplacement; solidBodyMotionFunction axisRotationMotion; axisRotationMotionCoeffs { origin (0 0 0); radialVelocity (0 -37.7 0); } } front { type fixedValue; value uniform (0 0 0); } back { type fixedValue; value uniform (0 0 0); } outerCylinder { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solver displacementSBRStress; displacementSBRStressCoeffs { //diffusivity uniform; // diffusivity directional (1 200 0); // diffusivity motionDirectional (1 1000 0); // diffusivity file motionDiffusivity; diffusivity quadratic inverseDistance 1("ImperialBlade.*"); } Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::solidBodyMotionFunctions::axisRotationMotion::transformation() const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #4 Foam::solidBodyMotionDisplacementPointPatchVectorField::solidBodyMotionDisplacementPointPatchVectorField(Foam::pointPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::pointMesh> const&, Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #5 Foam::pointPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::solidBodyMotionDisplacementPointPatchVectorField>::New(Foam::pointPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::pointMesh> const&, Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #6 Foam::pointPatchField<Foam::Vector<double> >::New(Foam::pointPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::pointMesh> const&, Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::pointMesh> const&, Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #8 Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #9 Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::readFields() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #10 at displacementMotionSolver.C:0 #11 Foam::displacementMotionSolver::displacementMotionSolver(Foam::polyMesh const&, Foam::IOdictionary const&, Foam::word const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #12 Foam::displacementSBRStressFvMotionSolver::displacementSBRStressFvMotionSolver(Foam::polyMesh const&, Foam::IOdictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfvMotionSolvers.so" #13 Foam::motionSolver::adddictionaryConstructorToTable<Foam::displacementSBRStressFvMotionSolver>::New(Foam::polyMesh const&, Foam::IOdictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfvMotionSolvers.so" #14 Foam::motionSolver::New(Foam::polyMesh const&, Foam::IOdictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #15 Foam::motionSolver::New(Foam::polyMesh const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #16 Foam::dynamicMotionSolverFvMesh::dynamicMotionSolverFvMesh(Foam::IOobject const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #17 Foam::dynamicFvMesh::addIOobjectConstructorToTable<Foam::dynamicMotionSolverFvMesh>::New(Foam::IOobject const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #18 Foam::dynamicFvMesh::New(Foam::IOobject const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #19 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #20 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #21 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Floating point exception (core dumped) |
March 24, 2014, 02:51 |
getting nan at the first transformation step
Rep Power: 12 |
when i unset FOAM_SIGFPE variable and run pimpleDyMFoam
I found this line Code:
solidBodyMotionFunctions::axisRotationMotion::transformation(): Time = 0 transformation: ((nan nan -nan) (-nan (-nan -nan -nan))) |
April 8, 2014, 08:41 |
Paritosh Vasava
Rep Power: 23 |
Did you manage to solve your problem?
April 8, 2014, 10:19 |
Rep Power: 12 |
Hi Vasava,
yeah, If you unset FOAM_SIGFPE you'll notice that, omega*t is happening at 0 time as well. Anyway I changed my dynamicMeshDict to use solidbody rotation and made my pointDisplacement as follows pointDsiplacement Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class pointVectorField; location "0.00001"; object pointDisplacement; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { "ImperialBlade.*" { type calculated; uniform (0 0 0); } front { type fixedValue; value uniform (0 0 0); } back { type fixedValue; value uniform (0 0 0); } outerCylinder { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libFvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { solidBodyMotionFunction axisRotationMotion; axisRotationMotionCoeffs { patches ("ImperialBlade.*"); origin (0 0 0); radialVelocity (0 -2160 0); } } // ************************************************************************* // I will update if manage to get reasonable mass-flow and forces. |
April 9, 2014, 00:29 |
Paritosh Vasava
Rep Power: 23 |
Ok. I was just curious about your dynamicMeshDict file. I am simulating objects thrown in to the air (like football) and am looking for help about mesh modifying with each time.
April 9, 2014, 03:10 |
Rep Power: 12 |
if you know mass of your body, there is a provision to do 6-DOF mesh motion. checkout the wingMotion2D tutorial, I haven't tried but I was getting many results about 6-DOF while I was searching for this problem.
April 9, 2014, 03:30 |
Paritosh Vasava
Rep Power: 23 |
I have tried some of the 6dof tutorial successfully and even modified some tutorial to my needs. But these tutorials are good for cases where the final position of the moving object is not far from the original position.
I am looking for rather adaptive mesh. Currently I am reading about dynamicTopoFvMesh which seems promising to me. Do you have any idea about adaptive mesh with openfoam?? |
April 9, 2014, 12:48 |
#8 | |
Rep Power: 12 |
Anyway, if it is possible for you, please post the dynamicMeshDict and pointDisplacement (if applicable) or any other dict important for the set-up. |
April 10, 2014, 01:28 |
#9 |
Paritosh Vasava
Rep Power: 23 |
While looking for help I realized that the solver dynamicTopoFvMesh may do the trick. I have started a thread and Sandeep Menon who has developed this tool is guiding on how to make it work with openFoam 2.2.0.
April 10, 2014, 01:34 |
#10 |
Paritosh Vasava
Rep Power: 23 |
Here is the pointDiplacement file. This is the file I modified from the floatingObject tutorial.
floating point error, mesh motion, openfoam-2.3 |
[Other] An updated look of dynamicFvMesh motion types | fedvasu | OpenFOAM Meshing & Mesh Conversion | 0 | March 10, 2014 13:40 |
dynamicMesh, dynamicFvMesh and meshPhi | mturcios777 | OpenFOAM Programming & Development | 0 | May 28, 2012 20:01 |
dynamicFvMesh usage | bongbongxanh | OpenFOAM | 0 | March 31, 2011 06:06 |
Valid dynamicFvMesh types in OF-1.6 | xfeng | OpenFOAM Running, Solving & CFD | 1 | January 18, 2010 04:38 |
TurbDyMFoam Unknown dynamicFvMesh type mixerFvMesh | david | OpenFOAM Running, Solving & CFD | 11 | February 16, 2009 16:30 |
