March 18, 2014, 17:35 |
[Waves2foam] alpha1 file
Rep Power: 13 |
Hi Foamers,
I am working on the Waves2foam package, and trying to add an (floating) object inside the geometry of the standingwave case using snappyHexMesh. Then I met a few problems. One problem that I am dealing with is as below. I want to modify the 'alpha1' file to increase the size of the internalField due to the result of snappyhexMesh, but i have no idea what's the rule for creating an alpha file or if it can be created automatically. Is there anyone who can help? Thanks in advance. Ellie Code:
Reading g Reading waveProperties Reading field p_rgh Reading field alpha1 --> FOAM FATAL IO ERROR: size 400000 is not equal to the given value of 1547000 file: /home/fgong/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/waves2Foam/tutorials/waveFoam/motorBikeWavePractice/0/alpha1 from line 18 to line 400556. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/fgong/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 236. FOAM exiting |
March 19, 2014, 14:56 |
Rep Power: 13 |
It's lucky that I already know what's the problem and solution.
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
