Foam-3.0-ext + MixingPlane Problems
Old   March 18, 2014, 14:42
Default Foam-3.0-ext + MixingPlane Problems
sirLentschi
lentschi is on a distinguished road
Hello community,
I have 2 perfectly matching and non-rotating/moving blocks, which are coupled by a mixingPlane Interface.
During calculation I always get an Floating Point Exception error. I have tried many different settings (and copied the settings from a mixingPlane tutorial) but get this error again:
Create mesh for time = 0
Initializing the mixingPlane interpolator between master/shadow patches: STAT1/STAT2
Reading field p
Reading field U
Calculating potential flow
CG: Solving for p, Initial residual = 1, Final residual = 0.00992722, No Iterations 82
continuity error = 9.22837e-06
Floating point exception (core dumped)
My boundary file looks like this:
6
INLET
type patch;
nFaces 171;
startFace 27788;
STAT1
type mixingPlane;
nFaces 171;
startFace 27959;
shadowPatch STAT2;
zone STAT1ZONE;
coordinateSystem
type cylindrical;
name mixingCS;
origin (0 0 0);
e1 (0 0 1); //Direction of Streamlines in z-Direction
e3 (1 0 0);
ribbonPatch
sweepAxis Theta;
stackAxis Z;
discretisation bothPatches;
WALL1
type wall;
nFaces 1624;
startFace 28130;
OUTLET
type patch;
nFaces 171;
startFace 29754;
STAT2
type mixingPlane;
nFaces 171;
startFace 29925;
shadowPatch STAT1;
zone STAT2ZONE;
WALL2
type wall;
nFaces 1624;
startFace 30096;
The mesh is ok, as can be seen in checkMesh:
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
*Number of regions: 2
The mesh has multiple regions which are not connected by any face.
<<Writing region information to "0/cellToRegion"
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Area [m^2] Surface topology
INLET 171 200 0.1 ok (non-closed singly connected)
STAT1 171 200 0.1 ok (non-closed singly connected)
WALL1 1624 1680 6.6 ok (non-closed singly connected)
OUTLET 171 200 0.1 ok (non-closed singly connected)
STAT2 171 200 0.1 ok (non-closed singly connected)
WALL2 1624 1680 6.6 ok (non-closed singly connected)
Checking geometry...
This is a 3-D mesh
Overall domain bounding box (-3.46945e-18 -2.77556e-17 0) (0.1 1 6)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Mesh (non-empty, non-wedge) dimensions 3
Boundary openness (5.95673e-17 -9.5346e-18 2.69053e-18) Threshold = 1e-06 OK.
Max cell openness = 1.96445e-16 OK.
Max aspect ratio = 13.0944 OK.
Minumum face area = 0.0001. Maximum face area = 0.0140221. Face area magnitudes OK.
Min volume = 2e-06. Max volume = 0.000160253. Total volume = 0.6. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0 Threshold = 70
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.24444e-09 OK.
Mesh OK.
Has anyone an idea to solve this problem?
Thanks in advance.
Regards,
Markus
lentschi is offline   Reply With Quote
Old   March 19, 2014, 05:02
sirLentschi
Problem solved!
Definition problem in the boundary file!
Old   March 22, 2014, 11:27
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
hi don lenardo,
I am using MRFSimpleFoam, 1/8 th of the fan. So far I am using Conformal Mesh, but now I want to reduce the computational time by using AMI interface,
my questions are:
is it possible in MRFSimpleFoam? I have attached the fig, please have a look. (the fan is in the middle)
I have edited (manually, I didt use createPatch utility) as follows:
constant/polyMesh/boundary
AMI4
type cyclicAMI;
nFaces 13000;
startFace 40391000;
neighbourPatch AMI3;
bridgeOverlap false;
AMI3
type cyclicAMI;
nFaces 26000;
startFace 40404000;
neighbourPatch AMI4;
AMI2
type cyclicAMI;
nFaces 23400;
startFace 40430000;
neighbourPatch AMI1;
AMI1
type cyclicAMI;
nFaces 13000;
startFace 40453400;
neighbourPatch AMI2;
when I run check Mesh, I am getting the warning message as you given in the first post.
Can you please help me solve the problem?
I am using OF-2.1.1
mixing plane, is it available in OF2.1.1?
can you please explain the procedure?
kind regards,
Sivakumar
sivakumar is offline   Reply With Quote
Old   March 31, 2014, 09:40
sirLentschi
Hello Sivakumar,
Mixing Plane is not available in OF 2.1!
Re-check your boundary file - maybe the boundaries are incorrectly defined and AMI 1 is not the neighbour of AMI2 (and AMI3 to AMI4 respectively).
Additionally, you have to add the following lines to each AMI-boundary:
transform noOrdering;
matchTolerance 0.001;
Hopefully this will help!
//Markus
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 27, 2008 00:58
[OpenFOAM] Problems using paraview 244 under open FOAM 141 or 13 sergio ParaView 0 March 13, 2008 14:52
[Commercial meshers] FOAM FATAL ERROR points deallocated hoerl OpenFOAM Meshing & Mesh Conversion 0 October 30, 2006 08:47
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 14:29
FOAM licensed free to academic institutions Nabla Ltd. Main CFD Forum 0 November 18, 2002 11:24
