find best solver ?
Old   March 9, 2014, 07:48
Default find best solver ?
S. Javad Saharkhiz
jvd.mechanic is on a distinguished road
hi every body
i want to find best solver for my case . how i can find which solver is the best for my solution?
How to find a suitable solution for my case?
thanks
jvd.mechanic is offline   Reply With Quote
Old   March 9, 2014, 11:40
Lieven
Lieven will become famous soon enough
Hi jvd,
This is probably the best place to start:
http://www.openfoam.org/features/standard-solvers.php
If you can't find the one you need in there, you will probably need to customize the one closest to your needs.
If you give a description of the case you want to simulate (turbulence/steady state/isothermal/compressible/...) we might be able to help you.
Cheers,
L
Lieven is offline   Reply With Quote
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 09:23
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 20:41
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 12:00
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
