March 7, 2014, 20:31 |
floating point exception
J. Brindley
Rep Power: 12 |
Not sure what's going on. Can't get simpleFoam to run
Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.081410493, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.061596729, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.091684187, No Iterations 3 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0059667553, No Iterations 5 GAMG: Solving for p, Initial residual = 0.40650934, Final residual = 0.0012374181, No Iterations 3 GAMG: Solving for p, Initial residual = 0.036894522, Final residual = 0.00027957842, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0062564286, Final residual = 4.8770264e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0013606213, Final residual = 1.2695641e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.00035198339, Final residual = 3.117196e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 0.00010876533, Final residual = 1.0124916e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 3.7107364e-05, Final residual = 3.2700493e-07, No Iterations 3 GAMG: Solving for p, Initial residual = 1.4011258e-05, Final residual = 1.2603484e-07, No Iterations 3 GAMG: Solving for p, Initial residual = 5.5796704e-06, Final residual = 3.7850784e-08, No Iterations 6 GAMG: Solving for p, Initial residual = 2.3340101e-06, Final residual = 6.442118e+119, No Iterations 1000 time step continuity errors : sum local = 1.2632859e+123, global = 4.4873194e+101, cumulative = 4.4873194e+101 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:? #9 Foam::incompressible::RASModels::kOmegaSST::correct() at ??:? #10 at ??:? #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 at ??:? Floating point exception (core dumped) |
March 7, 2014, 21:06 |
J. Brindley
Rep Power: 12 |
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : checkMesh Date : Mar 07 2014 Time : 20:04:09 Host : "AVA-411296" PID : 26818 Case : /home/kathyb/OpenFOAM/kathyb-2.3.0/run/SplitTipTesting/AOA/simplesolvefixed(donotuse) nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 30927 faces: 72559 internal faces: 60772 cells: 21783 faces per cell: 6.1208741 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 15749 prisms: 1429 wedges: 0 pyramids: 0 tet wedges: 128 tetrahedra: 2 polyhedra: 4475 Breakdown of polyhedra by number of faces: faces number of cells 4 1186 5 814 6 740 7 218 8 90 9 678 10 86 11 47 12 401 13 3 14 6 15 150 18 56 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 0 0 ok (empty) outlet 0 0 ok (empty) walls 40 67 ok (non-closed singly connected) frontBack 0 0 ok (empty) Foil 11747 13554 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.020220271 -0.010812593 -0.00023150215) (0.020260984 0.010818352 0.15183358) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-5.8212676e-17 4.5742309e-17 1.775036e-17) OK. Max cell openness = 2.9738872e-16 OK. Max aspect ratio = 21.38308 OK. Minimum face area = 6.6009305e-09. Maximum face area = 1.3716404e-05. Face area magnitudes OK. Min volume = 1.1250083e-12. Max volume = 2.2923998e-08. Total volume = 2.8560307e-05. Cell volumes OK. Mesh non-orthogonality Max: 62.160689 average: 13.151348 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.6576963 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 0.02; relTol 0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } U { solver PBiCG; preconditioner DILU; tolerance 1e-6; relTol 0.1; } k { solver PBiCG; preconditioner DILU; tolerance 1e-6; relTol 0.1; } omega { solver PBiCG; preconditioner DILU; tolerance 1e-6; relTol 0.1; } cellDisplacement { solver GAMG; tolerance 1e-5; relTol 0; smoother GaussSeridel; cacheAgglomeration true; nCellsInCoursestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pReffCell 0; pRefValue 0; residualControl { p 1e-4; U 1e-4; } } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; omega 0.7; } } cache { grad(U); } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; grad(k) cellLimited Gauss linear 1; grad(omega) cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) bounded Gauss upwind;; div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.5; laplacian(DomegaEff,omega) Gauss linear limited 0.33; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.33; } fluxRequired { default no; p; } // ************************************************************************* // |
March 8, 2014, 17:56 |
Lieven
Rep Power: 23 |
Hi olddirtybrindly,
Do you get the same crash when you run the case with pisofoam? Cheers, L |
Floating point exception with pimpleDyMFoam | ebah6 | OpenFOAM Running, Solving & CFD | 9 | November 1, 2017 06:58 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 11:21 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 17:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 04:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
