February 24, 2014, 06:14 |
OpenFOAM parallel running error in cluster
vishal
Rep Power: 13 |
Hi all,
I am trying to run my case at openFOAM in cluster. But somehow its not working and showing following error... Code:
[vishal@iceng1 case_parallel]$ mpirun --hostfile iceng1.hpc.com -np 4 turbulentFlameletRhoSimpleFoam -parallel >data& [1] 129047 [vishal@iceng1 case_parallel]$ -------------------------------------------------------------------------- Open RTE was unable to open the hostfile: iceng1.hpc.com Check to make sure the path and filename are correct. -------------------------------------------------------------------------- [iceng1.hpc.com:129047] [[35788,0],0] ORTE_ERROR_LOG: Not found in file base/ras_base_allocate.c at line 236 [iceng1.hpc.com:129047] [[35788,0],0] ORTE_ERROR_LOG: Not found in file base/plm_base_launch_support.c at line 72 [iceng1.hpc.com:129047] [[35788,0],0] ORTE_ERROR_LOG: Not found in file plm_rsh_module.c at line 990 -------------------------------------------------------------------------- A daemon (pid unknown) died unexpectedly on signal 1 while attempting to launch so we are aborting. There may be more information reported by the environment (see above). This may be because the daemon was unable to find all the needed shared libraries on the remote node. You may set your LD_LIBRARY_PATH to have the location of the shared libraries on the remote nodes and this will automatically be forwarded to the remote nodes. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that the job aborted, but has no info as to the process that caused that situation. -------------------------------------------------------------------------- mpirun: clean termination accomplished ^C [1]+ Exit 1 mpirun --hostfile iceng1.hpc.com -np 4 turbulentFlameletRhoSimpleFoam -parallel > data Thanks in advance Regards vishal Last edited by wyldckat; March 1, 2014 at 08:46. Reason: Added [CODE][/CODE] |
March 1, 2014, 08:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Vishal,
The error message clearly states: Code:
Open RTE was unable to open the hostfile: iceng1.hpc.com Code:
mpirun --hostfile iceng1.hpc.com Best regards, Bruno
March 10, 2014, 07:19 |
vishal
Rep Power: 13 |
[vishal@iceng1 SM1.kOmegaSST_parallel]$ mpirun -np 4 turbulentFlameletRhoSimpleFoam -parallel >data& [5] 24696 [vishal@iceng1 SM1.kOmegaSST_parallel]$ [iceng1.hpc.com:24697] [[5026,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 117 [iceng1.hpc.com:24697] [[5026,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174 [iceng1.hpc.com:24698] [[5026,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 117 [iceng1.hpc.com:24698] [[5026,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174 [iceng1.hpc.com:24699] [[5026,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 117 [iceng1.hpc.com:24699] [[5026,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174 [iceng1.hpc.com:24700] [[5026,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 117 [iceng1.hpc.com:24700] [[5026,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_util_nidmap_init failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_set_name failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- [iceng1.hpc.com:24697] [[5026,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128 [iceng1.hpc.com:24698] [[5026,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128 [iceng1.hpc.com:24699] [[5026,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128 [iceng1.hpc.com:24700] [[5026,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- [iceng1.hpc.com:24700] *** An error occurred in MPI_Init [iceng1.hpc.com:24700] *** on a NULL communicator [iceng1.hpc.com:24700] *** Unknown error [iceng1.hpc.com:24700] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort -------------------------------------------------------------------------- An MPI process is aborting at a time when it cannot guarantee that all of its peer processes in the job will be killed properly. You should double check that everything has shut down cleanly. Reason: Before MPI_INIT completed Local host: iceng1.hpc.com PID: 24700 -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 3 with PID 24700 on node iceng1.hpc.com exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [iceng1.hpc.com:24696] 3 more processes have sent help message help-orte-runtime.txt / orte_init:startup:internal-failure [iceng1.hpc.com:24696] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [iceng1.hpc.com:24696] 3 more processes have sent help message help-orte-runtime / orte_init:startup:internal-failure [iceng1.hpc.com:24696] 3 more processes have sent help message help-mpi-runtime / mpi_init:startup:internal-failure [iceng1.hpc.com:24696] 3 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal unknown handle [iceng1.hpc.com:24696] 3 more processes have sent help message help-mpi-runtime.txt / ompi mpi abort:cannot guarantee all killed I run my parallel case in one cluster only... Vishal Last edited by wyldckat; March 10, 2014 at 16:19. Reason: Added [CODE][/CODE] |
March 10, 2014, 16:22 |
Bruno Santos
Rep Power: 128 |
Hi Vishal,
A quick search online indicates that it's possible that you are using OpenFOAM with an incompatible Open-MPI version. Was OpenFOAM compiled with the cluster's own Open-MPI version or was it compiled with the version supplied with OpenFOAM? Best regards, Bruno PS: When you need to post code or screen output, such as the ones from your previous two posts, please follow the instructions from this link: Posting code and output with [CODE]
March 11, 2014, 02:02 |
vishal
Rep Power: 13 |
Hi Bruno,
Actually I compiled with cluster openmpi ..there might be some issue ican't find it out...So I changed the path in bashrc file of openfoam...and compiled with supplied version of OpenFOAM... Now this problem is showing.... Code:
[vishal@iceng1 SM1.kOmegaSST_parallel]$ mpirun -np 4 turbulentFlameletRhoSimpleFoam -parallel >data& [1] 77174 [vishal@iceng1 SM1.kOmegaSST_parallel]$ -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not find an executable: Executable: turbulentFlameletRhoSimpleFoam Node: iceng1.hpc.com while attempting to start process rank 0. -------------------------------------------------------------------------- ^C [1]+ Exit 133 mpirun -np 4 turbulentFlameletRhoSimpleFoam -parallel > data [vishal@iceng1 SM1.kOmegaSST_parallel]$ This is the path of flamelet solver... Code:
/export/home/vishal/OpenFOAM/OpenFOAM-2.1.1/flamelet-2.1/tutorials/turbulentFlameletRhoSimpleFoam/ Vishal |
March 11, 2014, 16:11 |
Bruno Santos
Rep Power: 128 |
Hi Vishal,
Try running with this command: Code:
foamJob -p turbulentFlameletRhoSimpleFoam For more information, run: Code:
foamJob -help Bruno
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 13:40 |
Running OpenFOAM in parallel | samiam1000 | OpenFOAM | 4 | November 11, 2013 09:01 |
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com | Markus Schmidberger | OpenFOAM Announcements from Other Sources | 0 | July 26, 2011 09:18 |
Running in Parallel on cluster | NewFoamer | OpenFOAM Running, Solving & CFD | 3 | November 3, 2010 17:20 |
Random machine freezes when running several OpenFoam jobs simultaneously | 2bias | OpenFOAM Installation | 5 | July 2, 2010 08:40 |
