strange results:Symmetry conditions but asymmetric results |
February 20, 2014, 22:27 |
zhanglei
Rep Power: 13 |
Hi! I recently met a headache problem about a laminar model. I assembled the interFoam with a energy equation and defined phase1 with cross-WLF viscosity model. unfortunately, as shown in figure, I got asymmetric results with Symmetry conditions. please help me!
February 22, 2014, 02:11 |
sepideh
Rep Power: 15 |
Hi there,
I have exactly the same problem in CFX. I was wondering if you have found any answer for this problem. Regards, Sep |
February 22, 2014, 03:49 |
zhanglei
Rep Power: 13 |
I try to find the reason from the discrete methods and the Algebraic process, and I have no answers now.
February 24, 2014, 11:08 |
Philipp
Rep Power: 27 |
Can you post, where in your model you have what kind of symmetry b.c.?
The skeleton ran out of shampoo in the shower. |
February 24, 2014, 20:54 |
zhanglei
Rep Power: 13 |
February 25, 2014, 03:35 |
Philipp
Rep Power: 27 |
What is on top / bottom, what is plotted in your picture?
February 25, 2014, 04:01 |
zhanglei
Rep Power: 13 |
February 25, 2014, 04:07 |
Philipp
Rep Power: 27 |
Does that mean you have u=0 at top, left, right and u=0.08 into the domain at the bottom?
February 25, 2014, 04:14 |
#9 |
zhanglei
Rep Power: 13 |
February 25, 2014, 04:21 |
#10 |
Philipp
Rep Power: 27 |
So this is time-dependent?
February 25, 2014, 04:24 |
#11 |
zhanglei
Rep Power: 13 |
yes,this is transient
February 25, 2014, 04:26 |
#12 |
Philipp
Rep Power: 27 |
Can you show the log file of the simulation?
February 25, 2014, 05:06 |
#13 |
zhanglei
Rep Power: 13 |
Create time
Create mesh for time = 0 // using new solver syntax: T { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } // using new solver syntax: T+T { solver smoothSolver; smoother ILU; nSweeps 3; minIter 0; maxIter 1000; tolerance 1e-06; relTol 0; } Reading g Reading transportProperties Reading TK=273.15 Reading field T Reading field pd Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model CrossWLF Selecting incompressible transport model Newtonian Calculating field g.h Selecting turbulence model type laminar time step continuity errors : sum local = 0.0016, global = -0.0016, cumulative = -0.0016 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.465223e-11, No Iterations 27 time step continuity errors : sum local = 1.194432e-13, global = -1.582459e-14, cumulative = -0.0016 Courant Number mean: 0.001270323 max: 0.4439866 velocity magnitude: 0.1109966 Starting time loop Courant Number mean: 0.00141147 max: 0.4933184 velocity magnitude: 0.1109966 deltaT = 0.001111111 Time = 0.001111111 MULES: Solving for alpha1 Liquid phase volume fraction = 0.0008888889 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.001739616 Min(alpha1) = 0 Max(alpha1) = 1 DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.02363721, No Iterations 6 DICPCG: Solving for pd, Initial residual = 1.341937e-07, Final residual = 4.663726e-08, No Iterations 1 DICPCG: Solving for pd, Initial residual = 1.669412e-07, Final residual = 5.153588e-08, No Iterations 1 time step continuity errors : sum local = 0.001140456, global = 0.0008470537, cumulative = -0.0007529463 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 5.301002e-08, No Iterations 17 ExecutionTime = 0.54 s ClockTime = 1 s Courant Number mean: 0.003166069 max: 0.61741 velocity magnitude: 0.1389173 deltaT = 0.0008888889 Time = 0.002 MULES: Solving for alpha1 Liquid phase volume fraction = 0.002372943 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.002980165 Min(alpha1) = 0 Max(alpha1) = 1 DICPCG: Solving for pd, Initial residual = 0.04042854, Final residual = 0.0007290781, No Iterations 2 DICPCG: Solving for pd, Initial residual = 0.2796866, Final residual = 0.006973493, No Iterations 5 DICPCG: Solving for pd, Initial residual = 0.2282629, Final residual = 5.127153e-08, No Iterations 18 time step continuity errors : sum local = 1.623944e-06, global = -3.650373e-07, cumulative = -0.0007533113 DILUPBiCG: Solving for T, Initial residual = 0.1983379, Final residual = 4.778879e-08, No Iterations 17 ExecutionTime = 0.8 s ClockTime = 1 s Courant Number mean: 0.9925878 max: 141.3327 velocity magnitude: 39.74981 deltaT = 3.144654e-06 Time = 0.002003145 MULES: Solving for alpha1 Liquid phase volume fraction = 0.00298302 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.002985876 Min(alpha1) = 0 Max(alpha1) = 1 DICPCG: Solving for pd, Initial residual = 0.1967935, Final residual = 0.007452839, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.1448237, Final residual = 0.004567321, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.1081815, Final residual = 9.174754e-08, No Iterations 16 time step continuity errors : sum local = 5.25175e-10, global = -1.027555e-10, cumulative = -0.0007533114 DILUPBiCG: Solving for T, Initial residual = 0.0001458371, Final residual = 2.35284e-08, No Iterations 3 ExecutionTime = 1.03 s ClockTime = 1 s Courant Number mean: 0.001923476 max: 0.1389821 velocity magnitude: 13.58828 deltaT = 3.772102e-06 Time = 0.002006917 |
February 25, 2014, 07:34 |
#14 |
Philipp
Rep Power: 27 |
I am not pretty familiar with the interFoam syntax, but it looks like there are no inner iterations each time step. So you can not expect each time step to be converged !? This could be a reason. Also, in general, I would not expect to get symmetric results just because I have symmetric b.c.
February 25, 2014, 07:45 |
#15 | |
zhanglei
Rep Power: 13 |
February 28, 2014, 05:02 |
#16 |
Robert Castilla
Rep Power: 17 |
i am getting a similar problem. I get nonzero Uz in a x-y plane defined as symmetryPlane in U. I don't understand the sentence: "in general, I would not expect to get symmetric results just because I have symmetric b.c.". What is the symmetry b.c. for then? Does it mean that the simulation has to be fully converged in each timestep to get symmtric results? Thanks Robert |
February 28, 2014, 06:35 |
#17 |
Philipp
Rep Power: 27 |
Hi Robert,
He doesn't use the "symmetry boundary condition", which means zero gradient by definition, but he uses symmetric boundary conditions on the left an right hand side of his domain. This is a huge difference. In a bluff body flow the bluff body can be symmetric, but that does not mean, that the flow is also symmetric all the time!
February 28, 2014, 08:09 |
#18 |
Robert Castilla
Rep Power: 17 |
Hi, Philipp,
Yes, you are right! My apologizes for the confusion. Nevertheless, is it normal that I get Uz in a symmetryPlane? Well, in fact maybe it is better if I open a new thread with this question... Thank you for your answer Robert |
February 28, 2014, 08:11 |
#19 |
Philipp
Rep Power: 27 |
Uz should be zero, because this is the actual b.c.
asymmetric results, interfoam |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
Newton Raphson - strange results | Bren | Main CFD Forum | 5 | February 11, 2009 10:47 |
time averaged results as initial conditions in CFX | mike | CFX | 8 | May 7, 2007 14:54 |
Strange results of car drag/downforce | Tudor Miron | CFX | 4 | March 14, 2004 05:49 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
