Correct velocity boundary condition for a wall in a rotating mesh
Old   February 19, 2014, 04:19
Default Correct velocity boundary condition for a wall in a rotating mesh
Pekka Pasanen
zordiack is on a distinguished road
Hi, I've been wondering what is the correct velocity boundary condition to use for a rotating mesh? My case is a centrifugal fan which has a wall patch for the rotor blades. I'm moving the mesh (all cells in one cellZone) using the following dynamicMeshDict:
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    cellZone        rotor;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        origin      (0 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
Which one should I use for the velocity boundary condition on the rotor patch?
        rotor_scale_solid
            type fixedValue;
            value uniform ( 0 0 0);
(the following is used in the propeller tutorial, but it doesn't make any sense to me to use movingWallVelocity for a rotating wall)
        rotor_scale_solid
            type movingWallVelocity;
        rotor_scale_solid
            type rotatingWallVelocity;
            origin (0 0 0);
            axis (0 1 0);
            omega 50;
I would be really grateful if someone could point me in the right direction.
zordiack is offline   Reply With Quote
Old   March 4, 2014, 08:33
Default movingWallvelocity
fedvasu is on a distinguished road
I hope by now you have figured it out, but if you are using OF-2.1 or above there is a tutorial case $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/propellor
where propellor has movingWallVelocity value(0 0 0), I too am working on rotating machinery problem with pimpleDyMFoam I use movingwall 0.
The motion of fan has to be captured with AMI mesh regions and you must specify the rotating velocity in constant/dynamicMeshDict.
there are other ways to model this kind of problem but I am not well-versed in them.
fedvasu is offline   Reply With Quote
Old   March 4, 2014, 11:11
Christian
ChristianR1988 is on a distinguished road
hey!i am also busy with a rotorating blade within an static casing.i also use movingwallvelocity (0 0 0) for the blade-wall and fixedvalue (0 0 0) for the casing...but i just use ami for the cyclic boundaries...
ChristianR1988 is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Rotating wall velocity boundary condition for axisymmetric flow problem diwakaranant SU2 1 March 24, 2013 00:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
applying boundary condition on rotating wall Haris Maharana Siemens 2 January 16, 2001 13:03
