Initialize the field using another simpler turbolence model
Old   February 13, 2014, 22:58
Default Initialize the field using another simpler turbolence model
ArathoN
ArathoN is on a distinguished road
hi foamers,
My friend told me that in Fluent there is an option to initialize the flow properties then run the desired the simulation. I searched for such an option on openfoam but i found nothing.
So i was thinking if i use a 1ep.-model like spalart-allmaras to initialize the flow then i swith to my desired RAS model, Does this improve my solution? and more importantly does the solution converge faster?
ArathoN is offline   Reply With Quote
Old   February 20, 2014, 15:51
ArathoN
Resolved.
First before running any simulation use:
refineMesh
It will help the first steps of the simulation.
Then if you use kEpsilon, it's better to run potentialFoam to initialize the U & p fields, you need to add this in the fvsolution file
potentialFlow
    nNonOrthogonalCorrectors 10;
then run
potentialFoam
Finally if you'll use the kOmegaSST initialize the fields with the data from the kEpsilon, the same with every other model derived from the kEpsilon. In genereal the kEpsilon is the fastest one so it's better to use it then feed the data to the others and the gain in cpu time reduction is huge.
That's all i learned. If some one has more advice i'll gladly hear him.
Old   February 21, 2014, 06:47
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
potentialFlow
Hi, i think this is exactly what Fluent does when using "Hybrid Initialization".
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   February 21, 2014, 11:07
ArathoN
Exactly I have a friend using fluent and old me about this initialization so after some test and research i found out how to do it in openFoam. In the case of kEpsilon running potentialFoam before the main solver has little effect (at least for the cases i studied), but in case of different models (LaunderSharmaLowRe, kOmegaSST,....) the initialization with kEpsilon helps really in reducing the time needed for the convergence.
Old   February 24, 2014, 03:41
Philipp
Aditionally to the speedup, I also had a case that diverged with a simple constant initialization but not with the potentialFoam init.
Old   February 27, 2014, 11:22
ArathoN
If you use very accurate schemes, sometimes the case will diverge. It's better to start the simulation with a diffusive scheme but robust, then after some iterations switch to the accurate one. That's what i do when i need to simulate complex cases.
Old   March 2, 2014, 22:55
Baris (Heewa)
shipman is on a distinguished road
Dear Arathon,
I also try to initialize my flow field using potentialflow before running my multiphase calculation according to your above explanation, but i couldnt succeed. in multiphase pressure dimension is kgm/s^2 however in potetialflow it is m^2/s^2. i set my cases as follows and but giving following error (is it error or not no idea). also how can i initialize the value of k and epsilon?? could you help to me pls...thanks
==>0/U
dimensions      [0 1 -1 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 -3.104 0);
    outlet
        type            zeroGradient;
    wall
        type            fixedValue;
        value           uniform (0 0 0);
=>0/P
dimensions [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
         type           zeroGradient;
    outlet
        type            fixedValue;
        value           $internalField;;
    wall
         type            zeroGradient;
==> fvSchemes:
ddtSchemes
    default              steadyState;
interpolationSchemes
   default         linear;
    interpolate(U)  linear;
divSchemes
    default              none;
   div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
gradSchemes
    default              Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(nuEff,U) Gauss linear corrected;
     laplacian(1,p)  Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
snGradSchemes
 default         corrected;
fluxRequired
    default         no;
    p               ;
==>fvsolution:
solvers
   "(U|k|omega)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0;
   p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
potentialFlow
sorry i forgat to paste the error:
DICPCG: Solving for p, Initial residual = 1, Final residual = 8.80882e-07, No Iterations 180
DICPCG: Solving for p, Initial residual = 0.168621, Final residual = 9.37342e-07, No Iterations 131
DICPCG: Solving for p, Initial residual = 0.00789625, Final residual = 9.67837e-07, No Iterations 115
DICPCG: Solving for p, Initial residual = 0.000384399, Final residual = 8.94174e-07, No Iterations 101
DICPCG: Solving for p, Initial residual = 2.60676e-05, Final residual = 8.91063e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 1.92316e-06, Final residual = 5.88908e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 7.12976e-07, Final residual = 7.12976e-07, No Iterations 0
continuity error = 0.0244929
Interpolated U error = 0.000203337
ExecutionTime = 6.04 s ClockTime = 6 s
shipman is offline   Reply With Quote
How to implement compressibility correction factor in k-epsilon model neeraj OpenFOAM Programming & Development 3 October 15, 2012 01:53
how to model a movable droplet sourse in electirc field Chande FLOW-3D 1 March 12, 2011 18:49
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 05:37
just a question about airfoil (Turbolence model and Cd) Maria Teresa Milesi FLUENT 3 April 7, 2000 10:56
I wish to find the proper model to validate the temperature field. G.H.Lee Main CFD Forum 1 May 6, 1999 03:05
