February 11, 2014, 22:05 |
BUBBLEFOAM ERROR for cavitation simulation
Baris (Heewa)
Rep Power: 13 |
Dear Foam Users,
I am trying to make cavitation simulation inside the nozzle. Before, I have used interphasechangeFoam, but i couldnt get satisfied result (http://www.cfd-online.com/Forums/ope...oam-error.html) so i decided to use bubbleFoam. As you can see above link my domain has inlet and outlet which are totally liquid and gas phase has formed due to sharped edge inside of throat. Therefore, i couldnt understand how can i set the 0/alpha file. as far as i understood from the tutorial of bubble foam, alpha shows dispersed phase volume fraction and if it is =1 totally vapor phase, if it is =0 totally liquid phase..(if i am wrong please correct me) In the bubblefoam tutorial, alpha set 0.5 at the inlet, but in my case there is no vapor at the inlet and outlet, only liquid, and when i set the internalField as 1, it gives error. Finally i set as follows but it gives again error as below. 0/alpha Code:
internalField uniform 0.33; boundaryField { inlet { type zeroGradient; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } wall { type zeroGradient; } HTML Code:
Courant Number mean: 2.08485e-06 max: 2.88724 deltaT = 1.93606e-13 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.000977614 Time = 0.00097761364 Max Ur Courant Number = 4.58454 DILUPBiCG: Solving for alpha, Initial residual = 2.3853e-07, Final residual = 2.4793e-11, No Iterations 1 DILUPBiCG: Solving for alpha, Initial residual = 3.6304e-08, Final residual = 7.48358e-12, No Iterations 1 Dispersed phase volume fraction = 0.302299 Min(alpha) = -0.00125876 Max(alpha) = 0.974554 DICPCG: Solving for p, Initial residual = 0.990648, Final residual = 0.0236273, No Iterations 2 time step continuity errors : sum local = 8.98747e+06, global = -0.118401, cumulative = -0.118401 DICPCG: Solving for p, Initial residual = 0.765502, Final residual = 9.40804e-11, No Iterations 255 time step continuity errors : sum local = 0.00104674, global = 1.93034e-05, cumulative = -0.118381 DILUPBiCG: Solving for epsilon, Initial residual = 0.999851, Final residual = 3.52247e-11, No Iterations 22 DILUPBiCG: Solving for k, Initial residual = 0.999992, Final residual = 9.42252e-11, No Iterations 812 ExecutionTime = 48734.2 s ClockTime = 49906 s Courant Number mean: 2.12678e+06 max: 1.26082e+12 deltaT = 1.53556e-26 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 0.000977614 Time = 0.000977613642 Max Ur Courant Number = 0.22989 DILUPBiCG: Solving for alpha, Initial residual = 5.25024e-08, Final residual = 5.06368e-12, No Iterations 1 DILUPBiCG: Solving for alpha, Initial residual = 5.5521e-10, Final residual = 1.13295e-13, No Iterations 1 Dispersed phase volume fraction = 0.302299 Min(alpha) = -0.00118087 Max(alpha) = 0.974554 DICPCG: Solving for p, Initial residual = 0.999998, Final residual = 0.0634955, No Iterations 2 time step continuity errors : sum local = 3.66498e-09, global = -4.6327e-10, cumulative = -0.118381 DICPCG: Solving for p, Initial residual = 1.32929e-05, Final residual = 9.55182e-11, No Iterations 153 time step continuity errors : sum local = 1.90516e+08, global = -465408, cumulative = -465408 DILUPBiCG: Solving for epsilon, Initial residual = 0.17329, Final residual = 17.7977, No Iterations 1001 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.11326e+25, No Iterations 1001 ExecutionTime = 48755.2 s ClockTime = 49927 s Courant Number mean: 2.10289e+13 max: 1.51796e+19 deltaT = 1.01159e-46 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 9 to 10 to distinguish between timeNames at time 0.000977614 Time = 0.0009776136421 Max Ur Courant Number = 3.24247 DILUPBiCG: Solving for alpha, Initial residual = 1.64427e-08, Final residual = 1.00091e-11, No Iterations 6 DILUPBiCG: Solving for alpha, Initial residual = 1.10356e-07, Final residual = 9.84183e-11, No Iterations 3 Dispersed phase volume fraction = 0.302299 Min(alpha) = -0.00118084 Max(alpha) = 0.974554 [4] [9] #0 Foam::error::printStack(Foam::Ostream&)#0 [3] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [9] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [4] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [9] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [4] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [9] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [9] #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [4] #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [3] #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [9] #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [4] #5 [9] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [9] #6 __libc_start_main [3] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [3] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [9] #7 [4] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [4] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [4] #7 [3] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [efs-desktop:28090] *** Process received signal *** [efs-desktop:28090] Signal: Floating point exception (8) [efs-desktop:28090] Signal code: (-6) [efs-desktop:28090] Failing at address: 0x3e800006dba [9] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [efs-desktop:28096] *** Process received signal *** [efs-desktop:28096] Signal: Floating point exception (8) [efs-desktop:28096] Signal code: (-6) [efs-desktop:28096] Failing at address: 0x3e800006dc0 [efs-desktop:28096] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f8f0c1664c0] [efs-desktop:28096] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f8f0c166445] [efs-desktop:28096] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f8f0c1664c0] [efs-desktop:28096] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xd0d) [0x7f8f0d19359d] [efs-desktop:28096] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7f8f0e228307] [efs-desktop:28096] [ 5] bubbleFoam() [0x432d9f] [efs-desktop:28096] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f8f0c15176d] [efs-desktop:28096] [ 7] bubbleFoam() [0x43ac7d] [efs-desktop:28096] *** End of error message *** [efs-desktop:28090] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f927c8054c0] [efs-desktop:28090] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f927c805445] [efs-desktop:28090] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f927c8054c0] [efs-desktop:28090] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xd0d) [0x7f927d83259d] [efs-desktop:28090] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7f927e8c7307] [efs-desktop:28090] [ 5] bubbleFoam() [0x432d9f] [efs-desktop:28090] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f927c7f076d] [efs-desktop:28090] [ 7] bubbleFoam() [0x43ac7d] [efs-desktop:28090] *** End of error message *** [4] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/bubbleFoam" [efs-desktop:28091] *** Process received signal *** [efs-desktop:28091] Signal: Floating point exception (8) [efs-desktop:28091] Signal code: (-6) [efs-desktop:28091] Failing at address: 0x3e800006dbb [efs-desktop:28091] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f3618f274c0] [efs-desktop:28091] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f3618f27445] [efs-desktop:28091] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f3618f274c0] [efs-desktop:28091] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xd19) [0x7f3619f545a9] [efs-desktop:28091] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7f361afe9307] [efs-desktop:28091] [ 5] bubbleFoam() [0x432d9f] [efs-desktop:28091] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f3618f1276d] [efs-desktop:28091] [ 7] bubbleFoam() [0x43ac7d] [efs-desktop:28091] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 28090 on node efs-desktop exited on signal 8 (Floating point exception). Any help will be very appreciated. Thanks in advance. |
February 14, 2014, 01:53 |
Baris (Heewa)
Rep Power: 13 |
nobody has any idea about this problem in bubblefoam?
And one more question is that can bubblefoam be used for cavitation modelling? thanks... |
February 16, 2014, 14:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi shipman,
Unfortunately there isn't enough information in your posts to make an educated guess on what exactly needs to be fixed. At least not with my experience on the topic, which isn't much. All I can do is suggest the following:
Bruno
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 04:36 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 05:43 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 14:02 |
