Multi-phase Lagrangian not working/converging |
February 11, 2014, 11:47 |
hasan hasan hasan
Rep Power: 13 |
Hallo every one,
i am really hoping and looking forward for some help! basically i am having a hard time making my simulation of a multi-phase with a porous medium converge or even work. so far this is what i have tried: the simplified model is basic a mix between angledDuctExplicit (geometry/porous medium) and vertical (Lagrangian/model and solver/ sizeDistribution: RosinRammler - no chemistry) channel tutorial. three dummy points were picked to be used a injectors (coneInjection). using the LTSreactingParcelFoam on a simplified model: 1. the simulation converges on a rough mesh but when using a finer mesh no converges! 2. on the finer mesh the simulation does not converge even after changed or switching on/off all of the fallowing:
4. using a different thermo or transport model didnt help! using the reactingParcelFoam on a simplified model: 1. the simulation crashes as soon as one parcel injected. 2. initialization of the simulation using a mapfield + another solver didn't help! 3. using a very small/smaller time step didn't help! using either LTSreactingParcelFoam/reactingParcelFoam on the real model: using all of the the variations: the model either cashes or when i am really really really really really really lucky: the simulations stops and gets stuck after adding new parcels. ------------------------------------------------------------------------------- given the bad documentation of the reactingCloud1properties file i think it would be helpful if any one can explain a way to understand how many parcels are introduced and how to calculate that number form the input parameters(massFlowRate/massTotal/duration/parcelsPerInjector/Umag/parcelsPerSecond). does any one have any ideas? |
convergence, lagrangian, ltsreactingparcelfoam, reactingparcelfoam |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
multi phase flow with chemical reactions in one phase | Habibfateh | OpenFOAM Programming & Development | 0 | February 10, 2014 07:33 |
using interface with Euler multi phase model | karimi | FLUENT | 0 | May 22, 2011 02:46 |
retrieve data from the Lagrangian phase in a cyclone separator | HugoRodrigues | Siemens | 0 | April 16, 2009 04:21 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
