Time varying jumpTable for uniformJump BC
Old   February 11, 2014, 09:50
Default Time varying jumpTable for uniformJump BC
Laurien Vandewalle
lavdwall is on a distinguished road
Hello everyone,
I want to use the uniformJump BC in OpenFOAM while calculating the required jump values in my solver. The uniformJump BC can read data from a csv-file where the first column is the time. I managed to write the required jump values as well as the time at each time step in the csv-file that is read by the solver. However, it seems that the solver only reads the csv-file once, i.e. only the initial jumps are read and the newly written (calculated) jumps at later time steps are not, so that the jump value doesn't change in time.
Is there a solution for this problem? Is it possible to re-read the csv-file at each time step? I already tried with correctBoundaryConditions() but this didn't work.
Many thanks and kind regards,
Laurien
lavdwall is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 14:52
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
