Need advice for compressible fluid simulation
Old   February 2, 2014, 08:15
Default Need advice for compressible fluid simulation
HouKen
houkensjtu is on a distinguished road
Hi Foamers!
I have been using interFoam to do simulation of incompressible two-phase flow and had a little bit experience on OpenFOAM source code developing.
Recently I am considering work on compressible fluid (refrigerant) inside air conditioner or refrigerator. Since I have no experience on how OpenFOAM does with compressible fluid I need your help!
To briefly describe refrigerant fluid characteristic:
1. Compressible, pressure, temperature and velocity should all be coupled by the ideal gas equation.
2. Should be subsonic. In fact I think velocity should be safely under 1m/s.
I googled for a while and notice there are several so called density-based compressible fluid solver provided by openfoam but have no idea which one is better for me to get start, or just should create one from scratch?
Plz leave your comment or advice!
Thx!
houkensjtu is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Heat transfer simulation of Gel(high viscous fluid) on a solid plate fshak92 FLUENT 1 October 26, 2012 12:32
variable density in single fluid simulation not running with total energy viking CFX 2 September 18, 2012 21:19
Density of multi fluid simulation unischlaf CFX 4 September 18, 2011 05:16
Fluid instability simulation Dinesh CFX 4 October 24, 2008 02:37
