SRFFreestreamVelocity BC does not work
Old   January 29, 2014, 10:34
Unhappy SRFFreestreamVelocity BC does not work
Tobias Adam
Tobias Adam is on a distinguished road
Hello everyone
I´m using SRFSimpleFoam. So I use SRFVelocity as Boundary Condition(BC) for the Inlet in the Urel file. This works perfectly good.
But when I try to use SRFFreestreamVelocity as BC for another patch an error message occurs:
--> FOAM FATAL IO ERROR:
keyword UInf is undefined in dictionary "/nfs/home/adam/OpenFOAM/adam-2.2.x/run/Bachelorarbeit/3sym-SRF/0/Urel.boundaryField.SHROUD"
file: /nfs/home/adam/OpenFOAM/adam-2.2.x/run/Bachelorarbeit/3sym-SRF/0/Urel.boundaryField.SHROUD from line 63 to line 66.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 402.
I don´t understand this! The data and folders of both patches are in the same directory. So it should be no problem for OpenFoam to use both of them, if one works perfectly good!
I´d be glad for any help.
Best regards Tobias
Tobias Adam is offline   Reply With Quote
Old   January 31, 2014, 05:17
Tobias Adam
My problem is, that I´m not very good in programming...
Do I have to move the folder of SRFFreestreamVelocity to another directory?
Old   January 31, 2014, 05:36
Andre Weiner
andre.weiner is on a distinguished road
it seems like at your patch the UInf variable isn't defined.
the patch entry should look like this:
    myPatch
        type            SRFFreestreamVelocity;
        UInf            uniform (0 0 0);
        relative        no;
        value           uniform (0 0 0);    // initial value
where UInf is the freestream velocity in the absolute frame.
Good luck!
andre.weiner is offline   Reply With Quote
Old   January 31, 2014, 06:19
Tobias Adam
Thank you very much!
As I looked for the patch files, I should have had a look on the required input for this patch.
I thought it was the same as for SRFVelocity.
Problem solved :-)
Best reagards Tobi
boundary condition, srf, srfsimplefoam
How to work with constant pressure? Martin Siemens 2 February 25, 2009 14:23
Getting FoamX to work shaun OpenFOAM Installation 12 March 23, 2007 09:55
work related to brake study of a vehical aero Siemens 3 November 23, 2006 08:43
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 13:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 22:03
