January 21, 2014, 10:39 |
bubbleFoam tutorial case with turbulence
Rep Power: 12 |
I copied the tutorial case for the bubbleFoam solver. I want to do a simulation with turbulence. I use OpenFOAM 2.1.1 Therefore I did the following changes in constant/RASProperties Code:
RASModel kEpsilon; turbulence on; printCoeffs on; Code:
laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; Code:
kFinal { $alpha; tolerance 1e-10; relTol 0; } epsilonFinal { $alpha; tolerance 1e-10; relTol 0; } Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : bubbleFoam Date : Jan 21 2014 Time : 16:36:39 Host : "markusUbuntuPC" PID : 8701 Case : /home/markus/OpenFOAM/markus-2.1.1/run/bubbleColumnTutorial nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field alpha Reading field p Reading field Ua Reading field Ub Reading transportProperties Calculating face flux field phia Calculating face flux field phib kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphak 1; alphaEps 0.76923; } wallFunctionCoeffs { kappa 0.41; E 9.8; } Reading field k Reading field epsilon Calculating field nutb Calculating field nuEffa Calculating field nuEffb Calculating field DDtUa and DDtUb Calculating field g.h Courant Number mean: 0.053388 max: 0.207813 PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 0.053388 max: 0.207813 Time = 0.002 Max Ur Courant Number = 0.172395 DILUPBiCG: Solving for alpha, Initial residual = 0.0021426, Final residual = 5.45235e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 8.98342e-05, Final residual = 1.63347e-12, No Iterations 3 Dispersed phase volume fraction = 0.36753 Min(alpha) = -0.0291739 Max(alpha) = 1.00075 DICPCG: Solving for p, Initial residual = 6.61573e-05, Final residual = 5.80641e-06, No Iterations 3 time step continuity errors : sum local = 1.42929e-05, global = -1.2315e-06, cumulative = -1.2315e-06 DICPCG: Solving for p, Initial residual = 1.14421e-05, Final residual = 9.11862e-11, No Iterations 65 time step continuity errors : sum local = 2.24465e-10, global = 4.65408e-12, cumulative = -1.23149e-06 DILUPBiCG: Solving for epsilon, Initial residual = 0.999995, Final residual = 1.59838e-11, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 5.3506e-11, No Iterations 42 ExecutionTime = 0.05 s ClockTime = 0 s Courant Number mean: 0.0534269 max: 0.207502 Time = 0.004 Max Ur Courant Number = 0.167411 DILUPBiCG: Solving for alpha, Initial residual = 0.00196793, Final residual = 6.01008e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 6.76905e-05, Final residual = 4.91127e-13, No Iterations 3 Dispersed phase volume fraction = 0.36753 Min(alpha) = -0.0172796 Max(alpha) = 1.00068 DICPCG: Solving for p, Initial residual = 0.000147469, Final residual = 5.45488e-06, No Iterations 2 time step continuity errors : sum local = 1.35211e-05, global = 9.39624e-07, cumulative = -2.91871e-07 DICPCG: Solving for p, Initial residual = 7.55098e-06, Final residual = 7.88894e-11, No Iterations 66 time step continuity errors : sum local = 1.95519e-10, global = 3.53133e-11, cumulative = -2.91835e-07 DILUPBiCG: Solving for epsilon, Initial residual = 0.841785, Final residual = 4.05909e-11, No Iterations 8 DILUPBiCG: Solving for k, Initial residual = 0.991263, Final residual = 4.04622e-11, No Iterations 53 ExecutionTime = 0.08 s ClockTime = 0 s Courant Number mean: 0.0534173 max: 0.207104 Time = 0.006 Max Ur Courant Number = 0.162844 DILUPBiCG: Solving for alpha, Initial residual = 0.00195171, Final residual = 5.86516e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 6.08262e-05, Final residual = 9.84431e-11, No Iterations 2 Dispersed phase volume fraction = 0.36753 Min(alpha) = -0.0062796 Max(alpha) = 1.0006 DICPCG: Solving for p, Initial residual = 8.24708e-05, Final residual = 6.16601e-06, No Iterations 2 time step continuity errors : sum local = 7.94365e-06, global = -2.95386e-07, cumulative = -5.87221e-07 DICPCG: Solving for p, Initial residual = 1.91089e-05, Final residual = 7.95161e-11, No Iterations 66 time step continuity errors : sum local = 1.02443e-10, global = 8.20917e-12, cumulative = -5.87213e-07 DILUPBiCG: Solving for epsilon, Initial residual = 0.677379, Final residual = 4.25709e-11, No Iterations 30 DILUPBiCG: Solving for k, Initial residual = 0.896536, Final residual = 6.25555e-11, No Iterations 44 ExecutionTime = 0.11 s ClockTime = 0 s Courant Number mean: 0.053389 max: 0.206805 Time = 0.008 Max Ur Courant Number = 0.157728 DILUPBiCG: Solving for alpha, Initial residual = 0.00193409, Final residual = 4.65798e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 5.91968e-05, Final residual = 8.86608e-11, No Iterations 2 Dispersed phase volume fraction = 0.36753 Min(alpha) = 0.00401149 Max(alpha) = 1.00056 DICPCG: Solving for p, Initial residual = 0.000286388, Final residual = 2.81435e-05, No Iterations 8 time step continuity errors : sum local = 1.92615e-05, global = 6.51325e-07, cumulative = 6.41128e-08 DICPCG: Solving for p, Initial residual = 8.11862e-05, Final residual = 9.94891e-11, No Iterations 73 time step continuity errors : sum local = 6.8192e-11, global = 5.36978e-12, cumulative = 6.41182e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.129222, Final residual = 9.15914e-12, No Iterations 25 DILUPBiCG: Solving for k, Initial residual = 0.757339, Final residual = 4.95247e-11, No Iterations 44 ExecutionTime = 0.13 s ClockTime = 0 s Courant Number mean: 0.0533735 max: 0.206451 Time = 0.01 Max Ur Courant Number = 0.156645 DILUPBiCG: Solving for alpha, Initial residual = 0.00191571, Final residual = 5.1319e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 5.70908e-05, Final residual = 1.42504e-12, No Iterations 3 Dispersed phase volume fraction = 0.367529 Min(alpha) = 0.0136969 Max(alpha) = 1.00051 DICPCG: Solving for p, Initial residual = 0.0279428, Final residual = 0.00133899, No Iterations 2 time step continuity errors : sum local = 0.00345412, global = 0.000955208, cumulative = 0.000955272 DICPCG: Solving for p, Initial residual = 0.00157094, Final residual = 7.43963e-11, No Iterations 75 time step continuity errors : sum local = 1.71787e-10, global = 5.45734e-12, cumulative = 0.000955272 DILUPBiCG: Solving for epsilon, Initial residual = 0.290322, Final residual = 3.03356e-11, No Iterations 15 DILUPBiCG: Solving for k, Initial residual = 0.989327, Final residual = 4.09582e-11, No Iterations 103 ExecutionTime = 0.17 s ClockTime = 0 s Courant Number mean: 0.0535236 max: 0.206076 Time = 0.012 Max Ur Courant Number = 0.346255 DILUPBiCG: Solving for alpha, Initial residual = 0.00205554, Final residual = 5.93573e-12, No Iterations 3 DILUPBiCG: Solving for alpha, Initial residual = 7.4096e-05, Final residual = 1.86119e-13, No Iterations 3 Dispersed phase volume fraction = 0.367529 Min(alpha) = 0.0228536 Max(alpha) = 1.00047 DICPCG: Solving for p, Initial residual = 0.905281, Final residual = 0.0282922, No Iterations 2 time step continuity errors : sum local = 0.0579972, global = 4.73252e-07, cumulative = 0.000955745 DICPCG: Solving for p, Initial residual = 5.80309e-11, Final residual = 5.80309e-11, No Iterations 0 time step continuity errors : sum local = 0.0615709, global = -2.19258e-08, cumulative = 0.000955723 DILUPBiCG: Solving for epsilon, Initial residual = 0.954852, Final residual = 5.33251e-13, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.00686899, No Iterations 1001 ExecutionTime = 0.28 s ClockTime = 0 s Courant Number mean: 0.125379 max: 6.10744 Time = 0.014 Max Ur Courant Number = 5.84605 DILUPBiCG: Solving for alpha, Initial residual = 0.0944949, Final residual = 1.81182e-11, No Iterations 7 DILUPBiCG: Solving for alpha, Initial residual = 0.204583, Final residual = 8.27286e-12, No Iterations 11 Dispersed phase volume fraction = 0.367529 Min(alpha) = 0.0235109 Max(alpha) = 2.333 DICPCG: Solving for p, Initial residual = 0.996327, Final residual = 0.0813598, No Iterations 1 time step continuity errors : sum local = 2.42079e+11, global = -5.14632e+09, cumulative = -5.14632e+09 DICPCG: Solving for p, Initial residual = 2.31678e-20, Final residual = 2.31678e-20, No Iterations 0 time step continuity errors : sum local = 3.13425e+12, global = -5.5099e+09, cumulative = -1.06562e+10 DILUPBiCG: Solving for epsilon, Initial residual = 0.262546, Final residual = 0.000207751, No Iterations 1001 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 7.34295e+07, No Iterations 1001 ExecutionTime = 0.5 s ClockTime = 1 s Courant Number mean: 1.8631e+12 max: 1.31834e+15 Time = 0.016 Max Ur Courant Number = 2.49974e+15 DILUPBiCG: Solving for alpha, Initial residual = 0.998815, Final residual = 3.6838e-11, No Iterations 120 DILUPBiCG: Solving for alpha, Initial residual = 1, Final residual = 1.63103e-11, No Iterations 51 Dispersed phase volume fraction = -1.35014e+24 Min(alpha) = -1.50905e+27 Max(alpha) = 2.04827e+26 DICPCG: Solving for p, Initial residual = 1, Final residual = 3.40176e+20, No Iterations 1001 time step continuity errors : sum local = 1.52312e+59, global = 2.12901e+42, cumulative = 2.12901e+42 DICPCG: Solving for p, Initial residual = 0.000401859, Final residual = 9927.39, No Iterations 1001 time step continuity errors : sum local = 7.30319e+98, global = -6.49763e+82, cumulative = -6.49763e+82 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #5 at ??:? #6 at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 at ??:? Last edited by setzberg; January 23, 2014 at 06:18. |
January 21, 2014, 11:34 |
Nima Samkhaniani
Rep Power: 25 |
your case is diverging ,you may want to play with your BC and your schemes
for Schemes i suggest to use an upwind (bounded scheme for k and epsilon)
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
January 23, 2014, 06:15 |
Rep Power: 12 |
Thanks for your reply! I also think that there is a problem with BC. The diverging Courant number is a problem, which occurs in several other threads. But there is also no hint how to solve this.
http://www.cfd-online.com/Forums/ope...ubblefoam.html http://www.cfd-online.com/Forums/ope...lent-case.html http://www.cfd-online.com/Forums/ope...rial-case.html http://www.cfd-online.com/Forums/ope...ubblefoam.html Can anyone tell me, how to change the BC so that the tutorial case works with turbulent flow? Or if the BC are not the problem, what has to be changed then? I already tried to change the scheme as nimasam suggests, but this does not prevent the Courant number to diverge. |
January 23, 2014, 06:34 |
Nima Samkhaniani
Rep Power: 25 |
whats ur BC for k and epsilon?
January 23, 2014, 06:56 |
Rep Power: 12 |
These are the BC as given in the tutorial case bubbleFoam
FoamFile { version 2.0; format ascii; class volScalarField; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.0002; boundaryField { inlet { type fixedValue; value uniform 0.0002; } outlet { type inletOutlet; inletValue uniform 0.0002; value uniform 0.0002; } walls { type zeroGradient; } defaultFaces { type empty; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1e-8; boundaryField { inlet { type fixedValue; value uniform 1e-8; } outlet { type inletOutlet; inletValue uniform 1e-8; value uniform 1e-8; } walls { type zeroGradient; } defaultFaces { type empty; } } |
January 23, 2014, 11:23 |
Nima Samkhaniani
Rep Power: 25 |
well, how did you calculate inlet values for k and epsilon? you can also use wallFunctions for wall patches.
October 15, 2015, 13:29 |
BubbleFoam limitations
Rep Power: 11 |
I want to use bubblefoam solver but it prevents on my work, because of bubblefoam limitations.
BubbleFoam limitations The diameter of the particles constituting the dispersed phase is assumed to be consistent. Aggregation, breakage and coalescence phenomena are not accounted for. What is your suggestion? DO you know any solver uses Euler mixture model ? thank you |
of2.1 |
Propeller case in AMI tutorial | reza1980 | OpenFOAM Running, Solving & CFD | 68 | November 28, 2017 21:37 |
Launder Shrma Low Reynolds turbulence model case setup | sivakumar | OpenFOAM Pre-Processing | 3 | September 14, 2013 08:20 |
pisoFoam elbow case with turbulence | inf.vish | OpenFOAM Running, Solving & CFD | 0 | August 19, 2013 05:17 |
Propeller tutorial case enquiries | chujeh2020 | OpenFOAM | 0 | August 26, 2012 01:18 |
Request for pipe bifurcation fluent tutorial case | Giorgos Momferratos | FLUENT | 0 | October 20, 2008 15:10 |
