January 17, 2014, 13:03 |
Can icoFoam handle turbulent flow or not?
Tony
Rep Power: 12 |
Dear foamers,
I know this may be a silly question and many people have asked similar questions, but I still want to make it clear whether icoFoam is able for turbulent flow or not? In terms of DNS, both laminar and turbulent flow solve the same equation. Given that I have very fine mesh and reasonable Reynolds number, will I get turbulent flow or not? Hope anyone can give me some hints. Thanks and regards, Tony |
January 17, 2014, 13:49 |
Anton Kidess
Rep Power: 30 |
So if your mesh is fine enough for DNS, and you say at that level the governing equations for laminar flow apply to turbulent flow, and icoFoam is valid for laminar flow - what reason can you think of that icoFoam would not be valid for turbulent flow simulations?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
January 17, 2014, 17:16 |
Tony
Rep Power: 12 |
Hi Anton,
Thank you very much for the reply. I was just wondering whether my understanding is right or not. Since normally people say icoFoam is for laminar flow, I am not sure if it is worth trying to get turbulent flow using icoFoam. Regards, Tony |
January 18, 2014, 08:08 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
There shouldn't be much doubts about it, because it's in the description of the solver: http://www.openfoam.org/features/standard-solvers.php and https://github.com/OpenFOAM/OpenFOAM...Foam/icoFoam.C Quote:
Best regards, Bruno |
January 18, 2014, 09:19 |
Anton Kidess
Rep Power: 30 |
Thats because for most applications DNS is prohibitively expensive. To get around this users use RANS or LES which solve additional equations, and those are indeed not implemented in icoFoam.
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 02:00 |
pressure distribution in water flow, differences in icoFoam and COMSOL | deniggo | OpenFOAM Running, Solving & CFD | 14 | September 30, 2010 04:48 |
modelling laminar and turbulent flow in the same | Ol | FLUENT | 2 | November 25, 2005 03:52 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
