heat transport question
Old   January 17, 2014, 08:39
Smile heat transport question
David
NewtoFOAM is on a distinguished road
I am doing a heat transfer simulation of air flow through a pipe where I model the fluid region and the solid thickness of the pipe. In the middle section the outer boundary of the solid pipe is fixed at a high temperature.
I am using chtMultiRegionSimpleFoam and I am fairly comfortable in using it. After convergence the velocity/pressure fields seem reasonable....however I am having a problem with the temperature field of the fluid region downstream of the heated section.
http://oi44.tinypic.com/2cs78d1.jpg
image of temperature field of fluid region
After a very short distance after the heated section the temperature field of the fluid is back to the inlet temperature.....i.e there is very little transport of heat with the flow.
Here is a plot of temperature along the center of the of pipe
http://oi39.tinypic.com/2l95ooo.jpg
As you can see...almost straight after the fluid passes through the heated section the temperature is back to what it was before it reached the heated section.....this doesn't seem right?
Mesh quality is good. Here are my b/c
Fluid region
U
Inlet velocity
Zero gradient outlet
0 velocity on wall
p
zero gradient inlet
zero gradient walls
reference pressure outlet
T
fixed inlet temperature (293K)
zero gradient outlet
fluid-solid interface compressible::turbulentTemperatureCoupledBaffleMix ed
solid region
T
heated boundary section fixed temperature 375K
all other non shared boundaries zero gradient
solid-fluid interface compressible::turbulentTemperatureCoupledBaffleMix ed
The flow has Re of 200 and so i'm not running this with turbulence.
What do you guys think?
Thanks in advance
NewtoFOAM is offline   Reply With Quote
advection, chtmultiregionsimplefoam, heat transfer
Turbulent Heat Flux Question deji OpenFOAM 5 August 1, 2016 10:27
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
any question about heat exchanger model egry FLUENT 0 October 25, 2008 21:14
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Heat flux question? Mark Main CFD Forum 0 February 13, 2004 10:03
