icoFsiFoam folder structure OF 2.2.1
Old   January 16, 2014, 11:04
Default icoFsiFoam folder structure OF 2.2.1
Philipp Reinhold
philipp1 is on a distinguished road
Hi everybody,
i'm trying to get the icoFsiFoam- solver started, but i don't really now, how the structure for this case has to look like.
i've already made
a link to 0 in the run/flappingConsoleSmall/solid/0 folder,
a link to constant in the run/flappingConsoleSmall/solid/constant folder,
a link to solid in the run/flappingConsoleSmall/fluid/0 folder and
a link to solid in the run/flappingConsoleSmall/fluid/constant folder .
is anything missing?
when i try to run the case i get
"--> FOAM FATAL IO ERROR:
cannot find file
file: /home/user/OpenFOAM/user-2.2.1/run/flappingConsoleSmall/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting"
thank you,
p
philipp1 is offline   Reply With Quote
Old   January 25, 2014, 18:08
Default using Allrun ?
Eric Bryant
codder is on a distinguished road
Dear philipp1 -
If you were using foam-extend-3.0, I would enthusiastically recommend to you the contents of:
cat $FOAM_TUTORIALS/solidMechanics/deprecatedTutorials/icoFsiFoam/flappingConsoleSmall/Allrun
... inside which, for example, $WM_PROJECT_DIR/bin/tools/RunFunctions is sourced.
To just get the tutorial to run, I would just execute:
cd $FOAM_TUTORIALS/solidMechanics/deprecatedTutorials/icoFsiFoam/flappingConsoleSmall/
./Allrun
... and, if 2.2.1 lacks the Allrun file, you may wish to check out the Allrun file from foam-extend-3.0's git.
Edit: Also, I'm not sure that 2.2.1 has the ability to run icoFsiFoam ??? You may want to check that out.
Best, Eric
codder is offline   Reply With Quote
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 10:30
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
[snappyHexMesh] Folder structure from snappyHexMesh elisenda OpenFOAM Meshing & Mesh Conversion 3 January 6, 2010 04:52
New ANSYS forum structure, what do you think? Peter FLUENT 10 February 6, 2009 05:07
New ANSYS forum structure, what do you think? Peter CFX 5 February 4, 2009 12:59
